Find_entity_by_id returns different Entity
In the attached file there is a component which contains a subcomponent and within this is only an edge.
When getting the subcomponent by find_entity_by_id (entity.guid) Sketchup is returning a different object with a different scale.
I already solved the issue by directly storing the entity in the list but I wonder what is causing this problem here.
Here is a simplified script to reproduce the issue:
def print_details(entity)
msg = “\n===============================\n”
msg += “#{entity}”
msg += “\nTYPE: #{entity.class}”
msg += “\nGUID: #{entity.guid}”
msg += “\nEntityID: #{entity.entityID}”
msg += “\nPERS ID: #{entity.persistent_id}\n”
msg += (“\nDef name: " + entity.definition.name + “\n”)
msg += “Matrix: #{entity.transformation.to_a.join(”,\n”)}\n"
puts msg
end
def id_test()
model = Sketchup::active_model
ent_instance = nil
model.entities.each do |entity|
if entity.is_a? Sketchup::ComponentInstance
entity.definition.entities.each do |sub_ent|
if sub_ent.is_a? Sketchup::ComponentInstance
ent_instance = sub_ent
break
end
end
end
end
print_details(ent_instance)
ent_tmp = Sketchup.active_model.find_entity_by_id(ent_instance.guid)
print_details(ent_tmp)
end
OUTPUT:
#Sketchup::ComponentInstance:0x0000028d81d68948
TYPE: Sketchup::ComponentInstance
GUID: 3kG1Q74FTAjRALzO029s2s
EntityID: 19876
PERS ID: 860278
Def name: centerline
Matrix: 1.0,
0.0,
7.048027557333175e-29,
0.0,
0.0,
1.0,
0.0,
0.0,
4.674090022094917e-28,
0.0,
30.617283950617278,
0.0,
1.830708661417323,
1.8307086614173222,
0.0,
1.0
#Sketchup::ComponentInstance:0x0000028d81b39320
EntityID: 17391
PERS ID: 859635
Matrix: 1.0,
0.0,
1.1100643402799756e-28,
0.0,
0.0,
1.0,
0.0,
0.0,
4.674090022094918e-28,
0.0,
48.22222222222222,
0.0,
1.830708661417323,
1.8307086614173222,
-6.310887241768095e-30,
1.0
=> nil
get_by_guid_issue.skp (634.1 KB)
If you have more than one instance of the outer component, then each will share the subcomponent instance because they have the same definition. (It is the definition that has the collection of entities.)
