Favourite architectural extensions
In my view this diversity is part of what makes SketchUp great. What would be bloat to some users are highly useful tools for others, and everyone can have it their way!
SketchUp is a bit like a workbench where some people use saw and hammer, other use screws, some use paint and fine brushes, a handful use a blowtorch and a few users may even use a weld. If you want to you can even install a full fledge wind tunnel.
I believe the real story here is the intended audience of the SU model. The sheer variety of the extensions seem to support this idea. @medeek hit the nail on the head with his post. Some SU modelers are into “details”, others are into the “big picture”. One tends to pick extensions that support customer requirements. This extension variety seems also to support @ene_su diversity comments. There may be better products to support “big picture” scenarios. In my opinion, the real strength of SU is in the detail arena. I may be biased, because this is my focus area. Putting an SU 3D image in the hands of tradesman often means less confusion on the job site. The old saying, “a picture is worth a thousand words”, comes to mind. Language barriers and trades interface issues become less of a problem. Better documentation and communication often leads to a better end product.
There is one thing that puzzles me.
The vast majority of these extensions are hosted either by the EW or Sketchucation (about equally). Sketchucation seems to be favoured by certain developers, such as @TIG and Fredo. Is there a reason for that? End users (if they could choose) might prefer a one stop shop like the 3DW.
The SketchUcation site was created before the Extension Warehouse. Many long-time extension developers started there, and still prefer it.
And it’s sometimes easier or quicker to get extensions published on SketchUcation than on EW.
OOPS - original made an accidental error and a bad pun
So it seems, but why? Maybe @john_mcclenahan’s answer in the following post gives a clue.
I find the following save a lot of time compared to doing things manually.
  • Material Replacer. Replacing materials over many nested components can take ages but not if you have Material Replacer.
  • Edge tools (find edge gaps). No matter how carefully you model, stray lines always appear which stop faces being created and can be frustrating and time consuming to find. Edge Tools has probably saved me hundreds of hours over the years.
  • TIG Roof and/or Vali Architects Instant Roof. Much faster than modelling roofs manually.
  • Flex Tools. I’ve only recently started using this and it’s great. SketchUp is very quick at modelling but not so quick at changing what you’ve modelled. Flex Tools addresses this. It would be great if it could be applied to all aspects of a model and not just individual components such as windows and doors.
  • Enscape. I’ve found it to be a very high quality rendering extension, easy use and also very fast (more or less instant depending on model size). I wouldn’t use anything else for rendering now as it allows models to be changed and then re-rendered instantly, rather than waiting (sometimes hours) on a render with other software.
    Selection Toys. Great for quickly selecting geometry that would otherwise take a while such as all faces or border edges.
These are also very useful.
  • Height above datum. Great for getting spot heights on imported terrain.
  • Extrude Lines. I use it often for creating plot divisions/fences.
Some guesses: to capitalize on the user base and years of accumulated information (context) that is on SketchUcation; because they like the way the site is managed; familiarity and habit.
SketchUcation provides a platform for much more extensive information about plugins, to see whether you really want them, and how to use them, feedback etc. Then there’s Smustard and developers who only provide extensions from their personal site. Why should Trimble be responsible for and in control of it all?
No reason at all. I was more interested in why developers choose one over the other. I think Tom may have answered that. But you could equally ask why Trimble gets involved at all. Having the EW makes it look a bit like there are approved extensions and unofficial ones.
Developers use their own site generally do so to be raise revenue, I imagine. Curic’s free extensions are available in the EW but you get taken to his site to buy the others.
Your post means that Add Height from Datum, Instant Roof, Material Replacer, Flex Tools, Edge Tools, and Enscape, all joint those that have two votes each.
I am not sure if I would count Enscape and other render engines as extensions, even when they embed in SU. I think of them as standalone software packages. Podium and VRay fall into this category.
ene_su,
Thanks for noticing and responding to this post!
Many of us want to see that someone on the “Team” is actually paying attention!
Keep up that attention, and good work!
Well said EosDawn,
So, a new saying might be: “A 3D picture (maybe from several angles) is worth a hundred thousand words”?
Hey Simon,
Brilliant idea to start this Poll …
I’ve picked up some ideas for Extensions I should look into …
I suspect others have as well, so thanks for flushing this out!
Good work as always, a positive contribution to our collective knowledge!
Keep Rocking!
CleanUp seems to be very popular and is mentioned a few times above. CleanUp does a lot of things. I’m curious which function of CleanUp do people consider the most valuable and most used?
in CleanUp 3 I’d say merge faces (remove coplanar edges) and remove stray edges are in close competition for favorites.
That combined with repair edges (lonely vertices) are a good general cleanup while modeling, to be used occasionally in one command as you go. But I find (in more recent versions) multiple commands in CleanUp can slow down terribly in larger models, regardless of how small the selection is, so I tend to use them one at a time.
Of course you don’t always want all of these, depending on what you are modeling.
On an aside, this quickly became a “favorite extensions” while doing architectural models thread–I think it’d be more interesting to know about specifically “architectural extensions” people use. I’d mention ValiArchitect Roof and Fence extensions, and Fredo’s Toposhaper (because it’s suited for building site models.). TIG’s height from datum is valuable once you have the terrain model.
Oh and of course Profile Builder. I’ve fallen down in use of that, personally, but it’s incredible.
