Have You Built Your First SketchUp Extension With AI?
Hello everybody
I wouldn’t have the slightest clue how to create a SketchUp extension without using AI, as I have no experience of Ruby but somehow I’ve created a couple recently that do exactly what I need.
Nobody else would bother creating them because they solve niche problems in my own workflow, but it got me wondering what others in the same boat have created.
If that’s you, I’d love to hear what you’ve created, what it does, and whether it’s genuinely improved your workflow.
I’m particularly interested in those little tools that solve problems you’ve been putting up with for ages because you didn’t have any other way of fixing them.
Perhaps we could share a few ideas and inspire each other.
Written by Kevin (not by AI) :grinning_face:
You can ask AI along the process, to placing the code into Sketchup Ruby Console that is under the menu’ “Extension then Ruby Console”
Hope it helps’
also the AI will direct you to placing the add-on you create into the appropriate folder
for Sketchup to find your ai add-on, as there are couple way to do it’
I made a custom extension for you a while ago :wink: It does something like ‘copy & place outside’. It was fun to do because it wasn’t something I would have thought of without the outside input. And I like the back and forth of making things. There have been a few extensions that were made based on ideas from the forum. Some seemed… weird. For example, someone wanted to select faces that are behind other faces. My response -and I think the Forum response in general- was, why? Sometimes you don’t ‘get’ what people are trying to convey until you work with their ideas for a time. Then you get that aha moment and understand their workflow and why they want an extension to work the way they describe.
A number of those were before vide coding was a thing. But they were AI assisted. The models are so capable now that doing one-off niche snippets/extensions is within anyone’s reach. It’s been mind boggling to watch.
Here are some CoPilot suggested versions of my response. It says option one sounds like me:
Yes. The idea is good, especially the point about not understanding someone’s workflow until you actually work through their idea. I’d mainly tighten it, smooth a few sentences, and make the ending connect more naturally to AI.
Option 1: Polished, but still sounds like you
I made a custom extension for you a while ago :wink: It does something like “copy & place outside.” It was fun to make because it wasn’t something I would have thought of without that outside input. And I like the back-and-forth of making things.
There have been a few extensions I’ve made based on ideas from the forum. Some of them seemed… weird at first. For example, someone wanted to select faces that were behind other faces. My response, and I think the forum’s response in general, was: Why?
Sometimes you don’t really “get” what someone is trying to convey until you work with their idea for a while. Then you have that aha moment and suddenly understand their workflow and why they want an extension to work the way they’re describing.
A number of those were made before vibe coding was really a thing, although they were AI-assisted. The models have become so capable now that making one-off, niche snippets and extensions is within almost anyone’s reach. It’s been mind-boggling to watch.
Option 2: A little more conversational / forum-like
I made a custom extension for you a while ago :wink: It does something like “copy & place outside.” That one was fun because it wasn’t something I ever would have thought of without someone else bringing the idea to me. I really like that back-and-forth process of figuring things out.
I’ve made a few extensions based on ideas that came from the forum. Some sounded… weird at first. I remember someone wanting to select faces that were behind other faces. My reaction, and I think the forum’s reaction in general, was basically: Why would you want to do that?
But sometimes you don’t really understand what someone is trying to accomplish until you spend some time working with their idea. Then you get that aha moment where their workflow suddenly makes sense, and you understand why they want the extension to behave in that particular way.
A number of those extensions were from before vibe coding was really a thing, although they were AI-assisted. Now the models have gotten so capable that one-off, highly niche snippets and extensions are within reach of almost anyone. It’s honestly been mind-boggling to watch that happen.
Option 3: Shorter and punchier
I made a custom extension for you a while ago :wink: It does something like “copy & place outside.” That was fun because it wasn’t something I would have thought of without outside input. I really enjoy that back-and-forth process of turning someone else’s workflow into an extension.
I’ve made a few extensions from ideas posted on the forum, and some seemed… weird at first. Someone once wanted to select faces that were behind other faces. My reaction, and I think the general forum reaction, was: Why?
But that’s one of the interesting things about making tools for other people. Sometimes you don’t understand the request until you spend some time with it. Then you get that aha moment and suddenly understand their workflow and why they want the tool to behave that way.
Some of those extensions predated vibe coding, although they were AI-assisted. Now the models are so capable that highly specialized, one-off snippets and extensions are within almost anyone’s reach. It’s been mind-boggling to watch.
My pick is Option 1. It preserves your slightly informal, reflective style rather than turning it into polished marketing copy.
Main changes: I corrected “vide coding” → “vibe coding,” tightened repetition, made the “Why?” anecdote land better, and strengthened the connection between outside ideas, understanding other people’s workflows, and what AI now makes possible.
You certainly did, James, and I still use it on every project I draw! :+1:
When I model a new glass structure, I end up with multiple boxes representing the exact overall dimensions of each glass unit. The outer face is used to detail the outer pane of glass, but the inner pane can have different dimensions and your extension allows me to select the inner face and automatically creates a named subgroup representing the inner pane.
It’s a niche workflow which you solved brilliantly for me, and the sort of thing that AI could now help someone with no experience create themselves.
That’s what I am asking in this thread. Have people managed to solve little problems in their own workflows using AI?
What helps me the most is having lots of README files with instructions for AI. That way, every time you start a new plugin, you’re not starting from scratch.
Whatever you learn while making one plugin, document it. If you end up creating 10 plugins, you’ve probably learned 10 different tricks along the way.
By the time you start your 11th plugin, you already have all that knowledge to build on, making things much easier. :grinning_face_with_smiling_eyes:
This is good to hear! If you have anything else you’re playing with, and would like to share, I’d be happy to take a look.
If you’re tinkering away and want to check your code (and save tokens) you can try this: Extension Preflight: local checks before Extension Warehouse submission - Extensions - SketchUp Community
It could help spot issues with your code. User beware: It could send you on some wild goose chases… which I’m hoping you’d take as ‘learning experiences’ :slight_smile: Otherwise, there’s Claude skill in linked thread (above) that can help keep your code up to snuff.
Have you made any more niche snippets for your work?
Hi James
Yes - I have made a number of really neat snippets using ChatGPT that have really helped my workflow. I give ChatGPT all the credit for the code as I just came up with the ideas. The purpose of starting this thread was to ask if anybody else has made any extensions which have helped there workflow, particularly where they had no previous experience, and to ask what do their extensions do?
When I draw a glass extension I always end up creating a section through the glass units which looks something like the first image below, although there are usually many more units. I then have to manually draw the individual glass panes and spacer bars which, having done it quite a few times, is pretty tedious at best.
My first extension lets me select the outer edge of each unit and then, with one click, the extension draws the glass, draws the spacer bars, and applies all the colours.
Its pretty basic stuff but I love it :blush:
The second extension solves a small problem I’ve had for years with Point Clouds. I use them extensively, and the first thing I do after importing one into SketchUp is to set its X, Y, Z and rotation coordinates to position it exactly where I want it. The problem is that I often close the Point Cloud project but that resets coordinates to zero, and sometimes I forget to record them which is a nightmare. My extension solves this by recording them automatically for me. ChatGPT managed to find out exactly where they were stored in the skp file, and it puts a tiny text file next to the skp file and it adds a new one if I ever change them.
Particularly if AI has given you the ability to solve your own problems and create your own extensions :+1:
I built my first 2 sketchup extensions maybe 9-12 months ago. Small ones just to help my workflow but they work great! Couldn’t have down it without vibecoding. Software value will go down to zero for most software. It’s a whole new world.
Actively working on building a rigging system for articulation, posing and animation. Pretty much allows me to pose and animate parts, from full articulation of a mecha model to something as simple as open/closing doors.
An example of said system in motion for moving parts on the bridge of a sci-fi ship.
I’ve already submitted a build of that one to the Extension Warehouse, and I already have the updated version ready to get reviewed once that’s approved and out lol.
I’m also (sparingly) working on an environment generator that uses about 200+ references to build houses and various other structures in various styles from fantasy to sci-fi so I can create populated environments in the background when taking pictures of and animating models in ARCticulation. I can forgo overly complex measurements since the goal isn’t realism, just the appearance of it.
On top of that while I know systems for UV wrapping exist in Sketchup via third party extensions, I’m (sparingly) working on one as an experiment to see if I can create a unwrap and edit system working directly through Sketchup and HTML Dialogs factoring in complex models (My mecha are all kinds of tris, ngons and quads going every little different direction causing for complex unwrap shenanigans). Limited success with this one, the first iteration worked great but it was converting the entire model to tris… now I’m working on baking it in and having mixed results, so I’m taking a break to build a ship, :stuck_out_tongue:
Working from a finger tip up, just getting the fingertip right has been a challenge…
So yeah it’s been a fun if time-consuming foray into vibe coding.
That’s seriously impressive work, although most of the technical info is beyond me :grinning_face:
It’s fascinating to see what other people create with the help of AI, or did you have some previous programming experience?
Thanks for sharing, and best of luck getting your extensions approved :+1:
Can you describe briefly what they do? :+1:
I only have SketchUp 2017 and a lot of the newer extensions don’t work in it. When I download a model from the Warehouse, many have layers that I do not need. I used AI for an extension that deleted all the layers in a model and put everything back on layer 0.
It was fun just seeing if I could make an extension that was actually useable
Some more playing around:
Projecting a cubemap on a flat surface. It actively updates via a fixed 1024x1024 mesh of tris, surprisingly buttery smooth. The idea was for inside my mecha cockpits to see outside from the monitors, or inside a ship, interior monitors projecting the ship’s exterior environment.
Neat the little things you can pull off… probably should’ve looked to see if such an extension exists in the first place.
I made it compatible with your own uploaded cubemaps, or it can use the built-in sketchup environments.
George Thorogood would call this, “Bad to the Bone”. I had to park my drone and downgrade SU. Pix4D that I used to get PCs was over $350/month. I ain’t smart ‘nuff ta pay that much fer learnin’ ferever! Sad part is PCs are so much FUN! Looks like you’ve got a niche problem solved. So are you able to ‘section’ your glass against the PC (or PC derived model geometry) to ‘scribe’ the glass or framing against? Or maybe what you showed above is fitted to the structure?
Hi Kevin,
Yes, over the past year I’ve built maybe a dozen very specific workflow extensions using AI that are immensely valuable to save time with repetitive labour-intensive tasks. My efforts include:
  • create editable 3D text, similar to the extension from thomthom but with adjustable line spacing and character kerning
  • create various cabinets (drawers, shelves, cubpoards) from basic rectangular solids
  • an extension to import a series of images and arrange them in a grid on screen and create a separate tag and scene to view them
  • create glass shopfronts
  • axis aligner that drills into components and fixes axes out of alignment with the global axis
  • a tool that numbers all instances of components in a model by placing 3D text on their plan view with their corresponding number (huge time saver)
plus a few more.
This is definitely a game-changing year for customising application environments, and not just for Sketchup. I’ve also used AI to read and edit Layout files. You can give Claude or ChatGPT a Layout file and ask it to check and fix dimension scales, find & edit text, plus a number of other tedious tasks.
Yes, that’s exactly what I do. I use the point cloud to create an accurate model of the existing structure in SketchUp, and then design the glass and metalwork around it although I never model the individual panes of glass just the overall units. It lets me account for irregularities in the building rather than rely on everything being straight and square. When I have finished a model like the one below, I use ‘Create Group from Slice’ to create sections, but now the glass linework and colours are all created by my plugin which saves a ton of work.
And I agree, point clouds are great to work with, although $350 a month would take some of the fun out of it! :grinning_face: What on earth do you get for that $350 per month?
That’s seriously impressive Mark, and exactly the sort of thing I hoped people would share. :grinning_face:
Like you, I’ve found AI opens up possibilities for creating tools to solve niche problems.
I’m intrigued with your comment about AI editing LayOut files. I didn’t know that was possible, but it sounds really useful.
Is that the actual LayOut file being edited or a PDF produced from the file?
Thanks for sharing :+1:
