I was trying to add autotext into LO which has a SKP model, I want the autotext refer to comp’s component instance name, but failed, it always appear to be <ComponentInstance>
Code as below:
doc = Layout::Document.open("D://test.layout")
docmodel=doc.pages.first.entities.detect{|e| e.is_a?Layout::SketchUpModel}
skpmodel=Sketchup.active_model
comp=skpmodel.active_entities.detect{|e| e.name=="Sumele"}
point_3d=comp.transformation.origin
point_2d = docmodel.model_to_paper_point(point_3d)
anchor = point_2d
textf = Layout::FormattedText.new("<ComponentInstance>", anchor, Layout::FormattedText::ANCHOR_TYPE_CENTER_CENTER)
text="<ComponentInstance>"
leader_type = Layout::Label::LEADER_LINE_TYPE_SINGLE_SEGMENT
target_point = point_2d
bounds = Geom::Bounds2d.new(2, 1, 1, 1)
label = Layout::Label.new(text, leader_type, target_point, bounds)
doc.add_entity(label, doc.layers.first, doc.pages.first)
cp = Layout::ConnectionPoint.new(docmodel, point_3d,comp.persistent_id.to_s)
label.connect(cp)
label.text=textf
While I refer to it succeed to show page number, I guess there must be some wrong in connection point, but I can’t figure it out.
Please edit your post correcting the code snippet …
THANK YOU
The people figures component are “face me” components whose bounds changes depending upon the camera position. I would say test using a normal component and use a 3D point that actually is touching the instance. Use something simple like a cube.
Using a box component doesn’t work too. even if 3Dpoint is inside the instance.
Can you attach both the .skp and .layout files to the original post please.
And your forum profile is not correct. It says you are using SU2019 but the Free web edition.
testautotext.skp (385.4 KB)
test1.layout (509.8 KB)
File uploaded, it is in Su 2021
Have you tried …
textf.display_text(doc.pages.first), leader_type, target_point, bounds
REF:
Alex I tried it as well, even reordering method calls to no avail.
Perhaps "<ComponentInstance>" is not considered autotext ?
adam
November 1, 2021, 10:27pm
9
Is the Sketchup.active_model actually the same model as the one in the LayOut document? It might be that the persistend_id of the component doesn’t match any persistent id’s in the SketchUp model viewport’s SketchUp model.
Adam
Yes . They are both in the root of my D: drive.
This skpmodel object’s file is the only SKP file in the D root directory.
The docmodel viewport’s reference is pointing at that same model with the same insertion data and time. The “Update” button is gray.
Thanks for looking at this Adam.
Adam I just got a Crash #22320 after trying the code below.
I had edited the text in the <> by putting a space between “Component” and “Instance”, nothing happened. I edited it again and deleted the space.
I right-click the viewport and chose Render Model and Splat!.
Test code ... (click to expand) ...
def label_it
doc = Layout::Document.open("D:/test1.layout")
docmodel = doc.pages.first.entities.detect {|e|
e.is_a?(Layout::SketchUpModel)
skpmodel = Sketchup.active_model
comp = skpmodel.active_entities.detect {|e| e.name == "acube" }
point_3d = comp.transformation.origin
anchor = point_2d
anchor,
text = "<ComponentInstance>"
label.connection_type= Layout::Label::CONNECTION_TYPE_AUTO
cp = Layout::ConnectionPoint.new(docmodel, point_3d, comp.persistent_id.to_s)
label.connect(cp)
doc.add_entity(textf, doc.layers.first, doc.pages.first)
label.text = textf
docmodel.render if docmodel.render_needed?
doc.save
end
AlexCui
November 2, 2021, 12:59am
12
Thanks, Dan, I got more crash in SU2021 and Crash with no error message!
The “” is an autotext, if you add an autotext manualy, and edit it to “” works well.
AlexCui
November 9, 2021, 3:03pm
13
Thanks, Dan, I got more crash in SU2021 and Crash with no error message!The<ComponentInstance>is an autotext, if you add an autotext manualy, and edit it to<ComponentInstance>, it works well.
