Extract coordinates of a point array
To extract coordinates of a point to assign them to another point
where the z is negative…thanks for your help.
example
pt1 = [50, 65, 0]
pt1a = [pt1.x + 5, pt1.y + 5, pt1.z - 5]
…“pt1.z - 5”…incorrect ???
result I would like to achieve = pt1a = [55, 70, -5]…
Joseph.
it works in Ruby Console for me…
pt1 = [50, 65, 0]
# => [55, 70, -5]
# I would more likely use
pt1  = [50, 65, 0]
a    = [5, 5, - 5]
pt1a = pt1.zip(a).map(&:sum)
# => [55, 70, -5]
# same result but easier to apply to any array...
what, where and how are you getting an error?
john
In fact, I asked for help because I can not understand ??
Img_4
Img_5
You are experiencing a limitation of the code-editor…
Try using something like this ?
pt1a = [(pt1.x + 5), (pt1.y + 5), (pt1.z - 5)]
I took some space…and now it works…
Img_6
Thank you so much to all of you for being interested…
Joseph.
It also so works, much better for reading code…
Thank you
Joseph
Img_7
Obviously it also works with spaces…
Thank you
Joseph
Img_8
Good evening, everyone…
:stuck_out_tongue_winking_eye::stuck_out_tongue_winking_eye::crazy_face::crazy_face:
Just to be clear, the original problem was that ’ -5’ (with a space before ‘-’ but no space between ‘-’ and ‘5’) is taken as a negative literal number not a subtraction operator combining two terms, so the expression ‘pt1.z -5’ is a syntax error. The various ways of adding or removing spaces around ‘-’ alter the interpretation of the expression, making clear that you intended a subtraction.
Edit: I hesitate to contradict @TIG, but this has nothing to do with the code editor.
OK…
One more cosa…se I add… pt1 = [50.cm, 65.cm, 0.cm]
How do I fix it ??? Wanting result of x, y and z in cm units of measurement…
I need to get = pt1a = [55, 70, -5] … unit of measurement in cm.
Thank you…
Img_9
also if pt1 = [50.0.cm, 65.0.cm, 0.0.cm] decimal numbers…
the result I always need pt1a = [55.0, 70.0, -5.0]…
Thank you
You’re probably correct - since I’ve never used the code-editor I can’t be sure.
It’s always best to use consistent spaces or none, and of course parentheses can help too…
pt1a.map {|n| Sketchup.format_length(n).split(' ')[0].to_f}
but “why”, can you give an overview of what you want to achieve…
SU Ruby has lots of shortcuts for dealing with user input/outputs…
john
What I want to get is this…
if pt1 = [50, 65, 0] integer in inches.
pt1a = [(pt1.x + 5), (pt1.y + 5), (pt1.z - 5)] if the syntax is right…
result is [55, 70, -5]
or if instead of inches I use the cm, being in Italy…
if pt1 = [50.cm, 65.cm, 0.cm] if the syntax is right. integer…
pt1a = [(pt1.x + 5.cm), (pt1.y + 5.cm), (pt1.z - 5.cm)] if the syntax is right…
result is [55, 70, -5] units of measurement in cm since I used .cm in pt1…
or even…
if pt1 = [50,0.cm, 65,0.cm, 0,0.cm] decimal number in cm… is it right to use the comma? 50,0.cm or you have to use the 50.0.cm
pt1a = [(pt1.x + 5,0.cm), (pt1.y + 5,0.cm), (pt1.z - 5,0.cm)] if the syntax is right…
result is [55,0, 70,0, -5,0]
thank you for your help…
Your ‘if’ syntax is wrong.
Also in Ruby the decimal separator is always .
Unlike your locale where it will probably be a ,
Ruby’s list separator is always a ,
Again unlike your locale where it will probably be a ;
So something like this will probably work…
if pt1 == [50.cm, 65.cm, 0.cm] ### note the double ==, to test equality
  pt1a = [(pt1.x + 5.cm), (pt1.y + 5.cm), (pt1.z - 5.cm)] ### note the single =, to set the reference
else
  pt1a = pt1.clone ### ? fallback result ?
end
All ok…se multiply “Done running code” by 2.54 the result
what you get is in cm…since Ruby code returns in inches…
Thanks, everyone
Joseph.
Such as …
pt1 = [50, 65, 0]
pt1a = pt1.offset( [5,5,-5] )
… or …
pt1 = [50, 65, 0]
pt1a = pt1.transform( [5,5,-5] )
Also (nitpick) these are array instances not points.
Thank you for your answer, Sir Dan…
health
Joseph.
Img_10
I apologize for forgetting to thank you.,
for his advice, any syntax errors, are due to the translator I use…
Joseph.
Thanks for the advice…
I only now understand the code syntax
how it should be used…
Joseph.
