Hi I’m new here. I have imported a sketchup file with ruby scritp. next I want to do the explode in the same ruby script, please help. The script code is as follows:
SKETCHUP_CONSOLE.clear
mod = Sketchup.active_model # Open model
ent = mod.entities # All entities in model
sel = mod.selection # Current selection
url = “https:\u002F\u002F3dwarehouse.sketchup.com\u002Fwarehouse\u002Fv1.0\u002Fpubliccontent\u002F42bda7c5-ae87-40a6-9f49-5ed72c9c02e7”
loadm = mod.definitions.load_from_url(url)
return unless loadm # good practice
could be “next unless loadm” inside a loop
point = Geom::Point3d::new( 0, 0, 0 )
myobject = mod.active_entities.add_instance(
loadm,
Geom::Transformation::new( point )
thank very much. I added the line of code cinst.explode and it does not work for me.
RUBY CODE:
cdef = mod.definitions.load_from_url(url)
return unless cdef # good practice
could be “next unless cdef” inside a loop
cinst = mod.active_entities.add_instance(
cdef,
Assuming ‘cinst’ is a ComponentInstance object
array = cinst.explode
if array
UI.messagebox “Exploded the component instance”
else
UI.messagebox “Failure”
end
Please, per the link @dezmo gave earlier, tell the forum’s formatter how to handle your code by putting
```ruby
on the line before the code, and
on the line after the code. As is, it is very hard to read and impossible to cut and paste for trying it out.
Exits a method. See methods syntax. If met in top-level scope, immediately stops interpretation of the current file.
The following worked fine for me in both SU2020 and SU2021 …
def load_and_explode(url, xform = IDENTITY)
puts "Failure to load definition from 3DW"
return false
end
# Insert an instance:
cinst = mod.active_entities.add_instance(cdef, xform)
# Explode the ComponentInstance object:
if array
puts "Exploded the component instance."
return array
else
puts "Failure to explode the component instance."
return false
end
end
url = "https:\u002F\u002F3dwarehouse.sketchup.com\u002Fwarehouse\u002Fv1.0\u002Fpubliccontent\u002F42bda7c5-ae87-40a6-9f49-5ed72c9c02e7"
load_and_explode(url)
#=> Exploded the component instance.
#=> [#<Sketchup::Group:0x0000020156cfac48>]
The bare table profile group was the result in both tests.
I would suggest however that the method take the 3DW model ID …
… as the first part of the URL could change as Trimble makes changes to 3DW.
(This would mean you only have 1 place in the code to fix future changes.)
def load_and_explode(model_id, xform = IDENTITY)
url = "https:\u002F\u002F3dwarehouse.sketchup.com\u002Fwarehouse"<<
"\u002Fv1.0\u002Fpubliccontent\u002F"<< model_id
return false
end
if array
return array
else
return false
end
end
