Thanks Dan,
I did find I could define a line from anywhere to the point I wanted
to start from.
My goal was to draw a rectangle 60â x 40â then have an 8â corridor
running down the middle of the long rectangle axis.
I started a line from the corner vertex of the base rectangle, then I
entered the end point, (16â, 0â). Then I drew the first corridor line.
This went well until I tried to erase the two construction lines I
used to locate the starting points of the two corridor walls.
These two lines lay along the Y axis wall and on top of the base
rectangle wall. I found it difficult to select just the short
construction line. I always ended up deleting the corridor section
along with the construction line.
So I re-drew the corridor section again.
As you can see, I need a lot of help.
My interest is in OpenStudio energy modeling. Once I get the geometry
in, I can carry on but Iâm struggling with the geometry.
Iâm working with Make and there are not any options for importing
other format floor plans, elevations, etc.
Thanks for you patience and great assistance!
At 12:37 AM 06/03/2016, you wrote:
http://forums.sketchup.com/users/danrathbunDanRathbun
March 6
crollinjones:
I am used to the command line in AutoCAD.
I am sorry about that. (I was also when I first came to SketchUp.)
The makers of SketchUp seem to have purposely made SketchUp
unCAD-like as must as they could.
This âspecify the edge start pointâ is an often asked for feature,
that has not yet been given to us.
What people are doing is drawing a unused temporary edge that end at
the start point you want (by specifying in the Measurements box,)
then continuing the tool drawing the actual edge by specifying itâs
end point. When done, go back and erase the first unneeded edge.
There is a sample âlinetool.rbâ in the Examples extension, that
might allow start point entry, or it could be tweaked if you know programming.
EDIT: Just checked the code of the sample âlinetool.rbâ, and it
mimics the native C edgetool.
From the code, a comment just inside the toolâs onUserText() callback:
We only accept input when the state is 1 (i.e. getting the second point)
⌠so the example would need tweaking.
http://forums.sketchup.com/t/beginner-questions/21202/5Visit Topic
or reply to this email to respond
To stop receiving notifications for this particular topic,
http://forums.sketchup.com/t/beginner-questions/21202/unsubscribeclick
here. To unsubscribe from these emails, change your
http://forums.sketchup.com/my/preferencesuser preferences
Chris Jones
14 Oneida Avenue
Toronto, ON M5J 2E3
Tel. 416-697-0056
