Hi, currently i am trying to define thermal zones in google sketchup. I have imported a house model from solid works and when i define the thermal zones of the rooms using ‘New energy plus zone’ it doesn’t recognizes the whole room. How can I edit this feature so it recognizes the areas in the correct way?
You’re using SketchUp 7 Make?
Share the .skp file so we can see exactly what you have set up and offer you some help.
Yes I am. I can’t share with you the skp file because it’s private, but attached there are some images that may help to understand the problem that i’m having. I am selecting the corners of the divisions so i can define the thermal zone in Energy+ but the ones that the program is recognizing are different from the real ones.
Ad you can see in the image, i have the contours of the rooms in red and when i select the corner to create a new zone, the yellow contour doesn’t match with the red. Do you know how to solve this? Thank you very much.
