Has anyone have a clue why the height of my dynamic component in Layout is wrong?
See appended LO file…
Schalter_Taster.layout (190.8 KB)
Maybe it is a matter of version? I have the newest version 2023.
Seems that you still have an older version?
And lately I had to update the DC extension…
Yes, I tried the latest version of SketchUp, but rolled back to 23.0.419 due to another bug in Layout (Major grid moving when I clip the grid to the margins).
I thought I had updated my DC extension as well, but possibly it rolled back when I went back to 23.0.419?? I’m not sure how all that works.
I tried it before. Also thought it has something to do with inch/ mm change, as in DC you have some trouble with it. I also started SU & LO again, nothing!! Very strange,
is there somebody with the latest version like me? I can only imagine this, as on your computer it works fine…
Yes sure. And i habe similar files with the same issue…
I scaled definition of Schalter_Taster_3D in the sketchup file that seems to fix it, can check on your version? it automatically updated
That would be too easy. I redefined scaling,
and also resetted scaling. No way. It is really strange, because I read the data
that I define in sketchup. So I defined a height of 200mm,
the switch will be positioned at 200mm. <DynamicComponent(hoehe)> in sketchup has this value.
In Layout it is wrong. When I add another field, reading the Z value, and then reading it in Layout, it works. Very strange!!!
Schalter_Taster.layout (161.1 KB)
