Im trying to draw a helical line with no extensions, and its alot harder than i thought haha. my goal is to make it any radius i need, and to have the distance between each helical path(pitch) to be what ever i choose:)
I know i could somehow use half circles, rotate them into palce but i seem to be missing some key ingredient to get it to be the dimensions i would like
i think i just figured it out…But i would like to see others ideas as well:)
ok, cool. im trying it out now. Mine was close. I had it copied 10 times, it looked great, but when i drew a cylinder with same amount of segments, up the center of the helix, exploded said helix, it would not attach itself to the geometry of the cylinder… ill try this method you showed and see what i can do.
thanks to your idea, i can know make accurate threads with the correct pitch and everything on the web version of SU. This will help alot of people.
those are M6x1 threads. with a pitch of 1mm, Major diameter of 6mm and a minor diameter of 4.917 and a pitch diameter of 5.35.
thanks a million for this. i am going to make a video of this. I will be sure to give full credit to you, anyother user that has used this method and the forums for this.
If you started with half a circle that you slightly rotated to achieve 1/2 pitch, that indeed wouldn’t match the cylinder around it. The half-circle endpoints wouldn’t have equal distances to the helix centerline. That’s what @Box’s method is for: all endpoints at equal distance of centerline in the end.
