YES
It is quite fast with small components from the distro library … try it …
# encoding: UTF-8
module Testing
@@loaded ||= false
class DragTool
def activate
@model = Sketchup.active_model
choice = get_definition()
if choice
@cancelled = @placed = false
@model.start_operation("DragInsert Component")
cdef = @model.definitions.load(choice)
@inst = @model.active_entities.add_instance(cdef,IDENTITY)
else
@model.select_tool(nil)
def deactivate(view)
if @placed && !@cancelled
@model.commit_operation
else
@model.abort_operation
def get_definition()
path = Sketchup.find_support_file("Components/Components Sampler")
choice = UI.openpanel("Choose a component ...",path,"*.skp")
def onCancel(reason, view)
puts "Cancel reason: #{reason}"
@cancelled = true
def onLButtonDown( flags, x, y, view )
ip = view.inputpoint( x,y )
point = ip.position
@inst.move!( Geom::Transformation::translation(point) )
view.invalidate
@placed = true
def onMouseMove( flags, x, y, view )
point = ip.position
view.invalidate
if !@@loaded
UI.add_context_menu_handler {|popup|
popup.add_item("DragInsert Component Tool") {
Sketchup.active_model.select_tool(DragTool::new)
@@loaded = true
