I dock palettes on my work surface for quick access.
I tap Window in the menu, choose what ever palettes I want on the work surface (Instructor/Components/entity Info/Layers/Scenes/Styles)
I then minimize the palettes by tapping at the top of each. Used to be when I minimized the palettes the title of each palette was visible. With my new computer the title is not showing so I have to tap each one to see what it is.
How do I get this feature back?
But the issue is that everything works like I like in the 2014 version but those customized by me settings did not transfer over to the new 2015 edition I just installed. I have read my settings should be on the newly loaded version.
… brings up a small informational dialog. (hit ALT+PrintScreen to copy just that dialog image to the clipboard. You can paste the image into MS Paint or whatever image editor you like to save it as a png.)
For this exercise, it is only important to know that it says OpenGL version 2 or higher.
Now I see what the communication issue is. You are responding to an issue I started two months ago. It fixed itself and is now not an issue.
I just put in another issue last week about the customized settings (toolbars) not carrying over from my 2014 version to my 2015 version. Hopefully someone will respond to that one.
