Hello Users,
I use Sketch Up with OpenStudio plugin. I need to model a building with 64 apartments. The building has a basement too. But the basement isn’t completely under the ground. The basement is one thermal zone and one space. But the outside boundary conditions of the surfaces are different for the part under ground (Outside boundary condition: Ground) and the part above the ground (Outside boundary condition: Outside). Does anyone know, how can I separate the surrounding surfaces of my basement into two parts?
Regards
Arne
Draw each section as if it is a separate wall. Select the joining faces and edges of both and hide. It will appear to be one wall but you will in fact have divided it into two.
Can I do that after I created the space? That is my file.
Variante 1 V2.skp (402.0 KB)
