Hello
I’m dimensioning a garden that is on angles. Normally I would select the start and end point and even though they are not in a line, the dimension tool would bring them to be perpendicular to each other/ orthagonal, so you can determine the horizontal distance from a set point.
However, I am getting this - see dimension 7.40 m. What I want is for the dimension to be perpendicular to the house wall (see dimensions above house wall - these were created using guidelines in Sketchup; however, when I remove the grid lines, the extension lines move and are no longer pointing to the ‘point’ of the garden the dimension refers to. I presume because the dimension line is not connected to the model).
I have tried to reset the axis so that the X & Y relate to the house wall to no effect.
Tried to upload the layout file but it has exceed the size allowed
