Is there a metod to refresh,redraw/rebuild DC after put into model?
I have model observer onPlaceComponent in witch I change some DC variables.
Variables are chanded but another dependent variables did not change.
Do you have any sugestions?
If I remember correctly, it’s a known issue that you have to update a component manually. (But I don’t find a link at the moment)
(Moved to the Developers > Ruby API category.)
Covered in other topics.
I posted an example method here:
Method to ask a dynamic component instance to recalc itself? / post 6
Dan you are great. Thank you.
in def onPlaceComponent(instance)
I can set up the value of attribiute using instance.set_attribute…
But i can not read value of attribiute using instance.get_attribiute…
In my case I modify one attribiute using another.
Do you have any ideas?
(1) The method name is spelled incorrectly.
It is: .get_attribute
not: .get_attribiute
(2) Many DC attributes are kept in the definition’s “dynamic_attributes” dictionary, not the instance’s “dynamic_attributes” dictionary. There are only specific situations where the attributes from the instance’s “dynamic_attributes” dictionary are used.
(2) of course, I forgot.
