Greetings!
Is there any (easy) way to achieve what is shown on attached picture? Basically I want to put tiles around the edge of my curved pool!
Greetings!
Do you want those tiles to be created from geometry (groups/components) or just a simple texture?
I prefer to use components, this way I can texture them and make them a bit more intricate. I tried using the Curviloft plugin, but that didn’t quite work. Also tried several plugins that can copy items along a path. I’ve uploaded the model if needed.
pool 3.skp (419.6 KB)
using geometry
There are extensions that directly create groups/components from faces.
using texture
Thanks, I will give the geometry option a try. Appreciate the help!
You’re welcome!
You could improve the geometry you created in your model for the desired result
or using a custom tile
Hi what is the name of the split extension?
Split Tools by TIG and available from Sketchucation.
Yeah I must have missed that one as well when it came out. Grabbed it yesterday!
Thanks Dave.
this will save me hours!
