I’m on a mac and been trying out SketchUp Pro trial so I’m not very up on it all. I’ve been trying to find out how to save an image as a vector in Layout from a SketchUp model face. Have sent the flat image “to Layout” but I can’t change the raster in SketchUp model tray to vector - it’s all greyed out.
Advice I have found online is all for PC and I looked in the forum but couldn’t find an answer. Is it a mac thing that you just can’t have can’t change the viewport from Raster to Vector or am I missing something? Advice says to change the viewport to Vector from Raster before you send to Layout but I can’t find that option anywhere in the Mac menus.
Thanks so much for your quick reply Anssi. After a bit more fiddling, I’ve discovered now I can get the tray active but when I make the image full size it disappears and has a triangle warning sign. Why is it doing that? Thanks!
Thanks. I’ve now managed to get the image back at full size 1:1 but the ‘page’ is too small and so the image is only partial. I try to enlarge the page setup and the document setup, and the paper size but it either creates an extra white page rectangle next to the original and/or doesn’t show all the image still. Hope I’m explaining this ok.
I’ve been trying to get this all day to send to a laser cutters as they need a vector image and I just can’t get it to work.
Do you mean you are selecting a scale of 1:1? If so, you may be looking at blank space between bits of geometry. You may need to select a scale that is appropriate to both model and paper size.
Thanks Simon, I’ve worked out how to get it active, turns out I wasn’t clicking on the right bit. So I’ve got it changed to a vector but it won’t go to the right size page when I put it as full scale 1:1.
As a point of detail, when you create something flat in SU, it shows the back face by default. that’s why it looks blue. That changes as soon as you start extruding it. But if you just want something 2D, best practice is to reverse the orientation of faces so that it turns white. That is especially important when you send things to 3d printers I believe and may apply to your CNC cutter too (not sure about that).
I had originally done the line sketch in Sketch Up because I had the free version and thought that would be ok for the laser folk but then got in a pickle because they said they wanted it in vector. I then downloaded the Pro trial as it can export vectors but couldn’t get it working. So frustrating knowing a little but not enough to make things work ok!
I also then redrew the sketch in Layout from scratch - I sent that to the laser cutters but they had closed before I got a reply so I don’t know if that was right.
Here’s the Layout image of my second sketch. is it a vector?
