Is there a way to create a football shaped container from a half sphere?
You could model the half sphere and then use Scale to mash it in the right direction to create a half football shape.
Here’s a rough example. From left to right:
- A circle for a Follow me path and a semicircle above. Offset to create the inner semicircle and edges to connect them to get the face. This will be the profile for Follow Me.
- Select the profile and scale it vertically to flatten it a bit.
- Run Follow Me.
- Select the bowl and use Scale to squash it side to side.
It also depends on where you live… for me does not need to be “mash it”
For a Buckeye, it’ll need to be mashed.
Perfect! Thank you!
A hemisphere IS half a football! Just cut it half. Whereas a rugby ball is oval, similar to an American football!
Two nations separated by a common language again.
Football, outside North America.
A Rugby ball
Truth! And cheers!
