I got issues with @thomthom algorithm (bad grid position), so I recoded my own algorithm… I use it on my Random Entity Generator plugin and it works very well:
require 'sketchup'
# REG plugin namespace.
module REG
# Grid of points.
module PointGrid
# Returns a point grid for a face.
# @param [Sketchup::Face] face
# @param [Integer] grid_size
# @raise [StandardError]
# @return [Array<Geom::Point3d>]
def self.face(face, grid_size = 10)
face_vertices = face.vertices
if face_vertices.size != 4
raise StandardError.new('Only quad faces are supported.')
end
lc_points_x = []
lc_points_y = []
face_point_grid = []
start_lc_count = 0
end_lc_count = grid_size
grid_size.times do
start_lc_count += 1
end_lc_count -= 1
lc_points_x.push(Geom.linear_combination(
start_lc_count.to_f / grid_size,
face_vertices.first.position,
end_lc_count.to_f / grid_size,
face_vertices.last.position
lc_points_y.push(Geom.linear_combination(
face_vertices[1].position,
face_vertices[2].position
end
lc_point_index = 0
lc_points_y.size.times do
start_lc_count = 0
grid_size.times do
start_lc_count += 1
end_lc_count -= 1
face_point_grid.push(Geom.linear_combination(
lc_points_x[lc_point_index],
lc_points_y[lc_point_index]
end
lc_point_index += 1
end
face_point_grid
end
# Returns a point grid for a group or component.
# @param [Sketchup::Group|Sketchup::ComponentInstance] grouponent
# @raise [ArgumentError]
def self.grouponent(grouponent, grid_size = 10)
raise ArgumentError, 'Grouponent parameter is invalid.'\
unless grouponent.is_a?(Sketchup::Group)\
|| grouponent.is_a?(Sketchup::ComponentInstance)
grouponent_transformation = grouponent.transformation
grouponent_point_grid = []
if grouponent.is_a?(Sketchup::Group)
grouponent_faces = grouponent.entities.grep(Sketchup::Face)
else # if grouponent.is_a?(Sketchup::ComponentInstance)
grouponent_faces = grouponent.definition.entities.grep(Sketchup::Face)
end
grouponent_faces.each { |grouponent_face|
not_trans_point_grid = face(grouponent_face, grid_size)
transformed_point_grid = []
not_trans_point_grid.each { |not_trans_point|
transformed_point_grid.push(
not_trans_point.transform!(grouponent_transformation)
grouponent_point_grid.concat(transformed_point_grid)
end
end
end
Usage
point_grid = REG::PointGrid.face(face)
or
point_grid = REG::PointGrid.grouponent(group_or_component)
Limitations
It works only on quad faces. So you can use Quadrilateralizer plugin if needed.
