I am wondering if there is a way to move an object a given distance as you do normally, but to multiply the copy/move so you can have an increasing distance between the parts, as each one is placed?. The model attached has a gap of 150mm between the horizontal pieces at the bottom, but that gap needs to increase incrementally to have a 200mm gap at the top. Can this be done? Is there some command that you can say +5mm or something for each item that is moved? I hope someone understands what I’m trying to do! Or would it be a / command but chang the distance gradually?
Thanks people. Although I’ve been using sketchup since 2007, I have so much to learn about it. This expression you wrote pcmoor (me not being very good on the maths side of life) will require tutorials and lots of reading to get a better grip on these generally.
