In the read only Live C API, let’s say we retrieve a reference to a group:
SUGroupRef group = ...
Now - is there a way to convert this C struct into a Ruby group object so that a face can be added?
It seems like it’s possible to retrieve the group with Model.find_entity_by_id
With v2020.2 or higher, I believe you would upcast to a SUEntityRef
using SUGroupToEntity()
… then use SUEntityToRuby()
[see the ruby_api.h page]
Re the persistent id pattern, in older SketchUp versions I suppose yes you can get the group id with SUEntityGetPersistentID()
after upcasting to SUEntityRef
, and then pass the integer (or double) to the Ruby side using the Ruby C API macros. INT2NUM
Excellent.
