The hole pattern updates the right size but the profile isnt. When i at the following code under the second profile:
dcs.redraw_with_undo(defn3)```
This is working good but the definition is now C-profiel#1 instead of C-profiel (with the same size as the first profile). So the load time will be much more and also for counting components this is not working well. Is there a code were this can't happen and only #1 will appear when you change size?
I can't find the solution by myself.
Thanks
Nice you found a solution yourself. I notice something strange (to me):
defn3 = componentdefinition
→ first, you set defn3 to the componentdefinition you just loaded
defn3 = model.active_entities.add_instance( defn3, [0.053.937,0.543.937,hoogte-1.88*3.937] ) → next you’re adding the defn3 componentdefinition to the active entities AND at the same time you’re setting the result (start of the sentence) to the same variable.
Why not use: defn3 = model.active_entities.add_instance( componentdefinition, [0.053.937,0.543.937,hoogte-1.88*3.937] )
This is my first ruby project and this code is part of a mezzanine floor builder. Everything is working. You can give up height, length, depth and number of fields etc.
Everything was done with different codes got from Internet, Dan and Tig. But now I want simplifying the code. So thank you!
No actually the add_instance() method adds a component instance of the defn3, so using that reference* is misleading. (*Ruby doesn’t really have variables.)
Does this make more sense ?
# 1e C-profiel------------------------------------------------------------------------------------------------------------
dlist = model.definitions
cdef3 = dlist.load( "Z:/Algemeen 2015/Systeemvloer/Tekeningen/Sketchup/C-profiel.skp" )
inst3 = model.active_entities.add_instance( cdef3, [0.05*3.937,0.54*3.937,hoogte-1.88*3.937] )
#afmeting en hoogte bepalen
cdef3.set_attribute( 'dynamic_attributes', '_lenx_formula', "#{str1*2.54-1}" )
dcs = $dc_observers.get_latest_class
dcs.redraw_with_undo(inst3)
# 1e C-profiel 2------------------------------------------------------------------------------------------------------------
inst = []
for i in 0..velden1-3
inst[i]= model.active_entities.add_instance( cdef3, [str1+i*str1+0.05*3.937,0.54*3.937,hoogte-1.88*3.937] )
end
Note:
I myself avoid using any reference names that begin with “def”. This way only method definitions start with lines beginning with those characters.
Also the for loop does not need a do keyword, and this will sometimes confuse color lexers of editors. It may also generate a warning when loading files.
