Bonjour tout le monde
pouvez vous svp m’aider sur un sujet, au fait je cherche à modifier avec un code ruby le repère d’un composant d’une position initiale par défaut à une nouvelle position que je choisisse .
merci d’avance
Are you trying to move a component definition’s insertion point ?
Please add your SketchUp edition and version to your forum profile.
The answer depends upon what version you are using.
Essayez-vous de déplacer le point d’insertion d’une définition de composant?
Veuillez ajouter votre édition et version de SketchUp à votre profil de forum.
La réponse dépend de la version que vous utilisez.
merci dan
je suis en version sketchup make 2017
I’ll reply for SketchUp 2020 and later as changing the actual insertion point has been removed.
* This should also work for older versions.
Instead you apply a transitional transformation to all the definition’s entities.
# Transforms all the entities in a component so that the origin is moved to a new point.
# @param comp [Sketchup::ComponentDefinition, Sketchup::ComponentInstance]
# @param to_point [Array(Length,Length,Length), Geom::Point3d, Geom::Vector3d,
# Geom::Transformation] - The new point for the origin or vector to move the entities by.
# @param uniquify [Boolean] Default is false - only used when comp is an instance.
def move_component_origin(comp, to_point, uniquify: false)
if uniquify # comp must be an instance
if !comp.is_a?(Sketchup::ComponentInstance)
fail(TypeError,"Argument(1) must be Component Instance when uniquify is true.",caller)
end
comp = comp.make_unique
end
cdef = comp.respond_to?(:definition) ? comp.definition : comp
if !cdef.is_a?(Sketchup::ComponentDefinition)
fail(TypeError,"Component Definition or Instance expected for argument(1).",caller)
end
if to_point.is_a?(Geom::Transformation)
t = to_point
elsif to_point.is_a?(Geom::Vector3d)
t = Geom::Transformation.new(to_point)
elsif to_point.is_a?(Geom::Point3d) || to_point.is_a?(Array)
t = Geom::Transformation.new(to_point.vector_to(ORIGIN))
else
fail(TypeError,"Transformation, Array, Point or Vector expected for argument(2).",caller)
end
cdef.entities.transform_entities( t, cdef.entities.to_a )
end
EDIT: fixed two places that need the new method call. (C# thinking got me.)
merci grand dan, je vais essayer ça et vous tiendrais au courant
milles merci
