I have a model with dynamic attributes-width and height.
dynamicObject.skp (338.4 KB)
The current code allows you to access all the attributes of the model.
SUInitialize();
SUModelRef model = SU_INVALID;
SUModelLoadStatus status;
SUResult res = SUModelCreateFromFileWithStatus(&model, "dynamicObject.skp", &status);
if (res != SU_ERROR_NONE) {
std::cout << "Failed creating model from a file" << std::endl;
return 1;
SUEntitiesRef entities = SU_INVALID;
SUModelGetEntities(model, &entities);
size_t instanceCount = 0;
size_t instanceLength = 1;
SUComponentInstanceRef instance = SU_INVALID;
SUEntitiesGetInstances(entities, instanceLength, &instance, &instanceCount);
SUDynamicComponentInfoRef dc_info = SU_INVALID;
SUComponentInstanceCreateDCInfo(instance, &dc_info);
size_t attributesLength = 3;
size_t attributesCount = 0;
SUDynamicComponentAttributeRef attributes[] = SU_INVALID;
SUResult result = SUDynamicComponentInfoGetDCAttributes(dc_info, attributesLength, attributes, &attributesCount);
if (result == SU_ERROR_NONE) {
// TODO something with attributes
Need help implementing code that changes the values of dynamic attributes when using the Sketchup C API.
