Dear Friends,
I used following code
def enableVCB?
return true
end
Also when I call it answer is true but when I write a number VCB value don’t change just its background color change to yellow. 1- Can you help me to solve this problem? 2- How can I read number from VCB value? 3-Can you send me linetool.rb if legal?
This is a Tool
callback method that the SketchUp engine calls when a Ruby Tool
is active.
You or your code never call it directly.
Your code can only read VCB text from within an active Tool
Your tool must define a #onUserText
callback method.
#onUserTest work’s well, but my first problem exist. My codes is similar to “line tool”. In my software I use " Sketchup.vcb_value = ll". it work’s well but when I type a number, it cannot show on vcb. In line tool vcb shows length but when we type a number, vcb shows number. Can you help me for this problem?
I explained it, so apparently not.
ALSO … you have not posted any code that I could see what is wrong !
No. It is posted in the official extension tutorials. Go get it yourself.
https://github.com/SketchUp/sketchup-ruby-api-tutorials/tree/master/examples/02_custom_tool
To show my problem I wrote following simple code.
# encoding: UTF-8
# Documentation block ...
require 'sketchup.rb'
module MajidMahmoudi
module MajWallTest
class MajWall
def init()
@input = Sketchup::InputPoint.new
@pt = [@input.position]
@pt[0] = @input.position
@pt[1] = @input.position
@distance = 0.0
end
def activate
init()
end #activate
def onMouseMove(flags, x, y, view)
@input.pick view, x, y
view.invalidate
if @distance != 0
p "Distance = #{@distance * 2.54}"
@distance = 0
end
end
def onUserText(text, view)
@distance = text.to_l
Sketchup.vcb_value = @distance
rescue ArgumentError
view.tooltop = 'Invalid length'
end
def draw view
if @input.valid?
ll = @pt[0].distance(@pt[1])
view.line_width = 3
view.draw_polyline @pt[0], @pt[1]
end # if
end # draw
end #class Wall
# unless file_loaded?(__FILE__)
UI.menu("Plugins").add_item("MajWall") {
Sketchup.active_model.select_tool(MajWall.new)
# file_loaded(__FILE__)
# end
end #MajWallTest
end #MajidMahmoudi
If you write a number then enter, you can see it n console but cannot see in vcb.
It seems to work okay for me. (If you move the mouse it wipes out what your code put into the VCB.)
Except that it does not honor the user’s model units. I typed 80 ENTER and the VCB showed 80.0000"
(inches) but the Console said 203.2
You also need a view.invalidate
call in a deactivate
method so that the view is cleared when another tool is activated.
It is traditional to use blue color for rubber banding in virtual tool draws.
Your SU unit is Inch and mine is cm. I changed unit. Thank you for your help.
For people whom have same problem. I used “Sketchup.vcb_value = ll” in (def draw view) and it makes this problem for me. After I move it to (def onMouseMove(flags, x, y, view)) my problem solved.
