Can I fire multiple rays at the same time using the raytest command?When there are more detection points, the program will run very slowly, and I want to be able to issue multiple ray inspections at the same time, or multi-threaded calls to the raytest command.I tried to call raytest multi-threaded, but it doesn’t seem to work, so let’s take a look at it.I call raytest to detect 24 dots of a circle, divided into two groups and run with two threads, the program did not report an error but the result did not come out
示例.skp (100.5 KB)
# Default code, use or delete...
mod = Sketchup.active_model # Open model
ent = mod.entities # All entities in model
sel = mod.selection # Current selection
detect_point = [[2.68, 4.22, 0.0], [3.68, 3.38, 0.0], [4.43, 2.32, 0.0], [4.88, 1.09, 0.0], [5.0, -0.21, 0.0], [4.77, -1.5, 0.0], [4.22, -2.68, 0.0], [3.38, -3.68, 0.0], [2.32, -4.43, 0.0], [1.09, -4.88, 0.0], [-0.21, -5.0, 0.0], [-1.5, -4.77, 0.0], [-2.68, -4.22, 0.0], [-3.68, -3.38, 0.0], [-4.43, -2.32, 0.0], [-4.88, -1.09, 0.0], [-5.0, 0.21, 0.0], [-4.77, 1.5, 0.0], [-4.22, 2.68, 0.0], [-3.38, 3.68, 0.0], [-2.32, 4.43, 0.0], [-1.09, 4.88, 0.0], [0.21, 5.0, 0.0], [1.5, 4.77, 0.0]]
detect_point1 = detect_point[0..11]
detect_point2 = detect_point[12..23]
occlusion_points_number1 = 0
occlusion_points_number2 = 0
result1=Thread.new do
detect_time = Time.utc(2021,1,17,10,50,0)
info=mod.shadow_info
info["Displayshadows"]=true
info["DisplayOnGroundPlane"]=true
info["ShadowTime"]=detect_time
info["Latitude"]=36.02
info["Longitude"]=100.54
direction_towards_sun = info["SunDirection"]
detect_point1.length.times do |i|
ray=[Geom::Point3d.new(detect_point1[i]),direction_towards_sun]
ignore_hidden_geometry = false
result01 = mod.raytest( ray, ignore_hidden_geometry )
if result01==nil
else
occlusion_points_number1 +=1
end
end
end
result2=Thread.new do
detect_point2.length.times do |i|
ray=[Geom::Point3d.new(detect_point2[i]),direction_towards_sun]
result02 = mod.raytest( ray, ignore_hidden_geometry )
if result02==nil
else
occlusion_points_number2 +=1
end
end
end
result1.join
result2.join
