I’m trying to show alternative designs to a Shop Counter. I made the original into a group but can’t seem to make and edit a copy, i.e. when I deselect the first group I lose all copies as well. Any suggestions
You can edit groups independently, maybe your “groups” are components? You can make a component unique in its context menu… but I’m not sure if this is the question. Do you have an example image or model?
Hi Tony,
It seems your description/terminology has us a bit confused.
Perhaps these tutorials will help answer your question.
Feel free to ask follow-up questions.
The array powers of the Move and Rotate tools…
Hi GeorgeThanks you so much for getting back to me . It’s the first time i’ve ever used a forum like this so I wasn’t sure what to write. I think in this case that I have solved the problem. What I was trying do was to set up some scenes that I could quickly show my client - the same perspective but with two different types of reception counters. When I copied the first counter ( which I had made into a group and saved as a layer ) to then alter it for a second design style, I found that I couldn’t deselect Counter 1 without also deselecting counter 2. I realised that I hadn’t saved counter 2 as a separate layer!Sketchup is a wonderful program but it’s frustrating when you make little mistakes that can impact in a big way.Once again that you for your time RegardsTony
Hi Tony,
You didn’t mention using layers until now.
Perhaps you’ve read this already. If not, here you go!
Required reading before using Layers in SketchUp:
Does SketchUp Support Layers? — SketchUp Documentation w/ Video
