Calculating rotation transformations
Good morning
I need some help calculating rotation transformations.
I have a vehicle that follows a path formed by a non-planar curve.
I want to get the transformation at each point of the curve for the vehicle so that:
Its x axis is collinear with the vector formed by the segment of the curve
Its z axis is collinear with the normal of the plane of the ribbon.
I get there for a plane curve, but not for a 3d curve.
How do you get the angles of rotation
Thank you for your help
It sounds like you need the angle between any 2 planes. I use the following code to get the acute angle between faces f1 and f2 (both Sketchup::Face objects):
f1_vec, f2_vec = f1.normal, f2.normal
angle = f1_vec.angle_between(f2_vec)
Note that angle is expressed in radians. You can convert to degrees by using angle.radians.
:bulb: My idea:
Let’s assume you have a
# a Sketchup::ComponentInstance :
vehicle
# a Sketchup::Face. :
face
# a Sketchup::Edge (one of the edges that bounds the above face) :
edge
# Geom::Point3d on the above edge (can be e.g.: edge.start or edge.end ):
current_position
Then you can construct a transformation
xaxis = edge.line[1]
zaxis = face.normal
yaxis = xaxis * zaxis
origin = current_position
tr = Geom::Transformation.new(xaxis, yaxis, zaxis, origin)
and apply to the vehicle instance, considering its current transformation inverse
tr_vehicle_inv = vehicle.transformation.inverse
vehicle.transform! tr * tr_vehicle_inv
Thank you for your answers!
I’m watching tonight, I’m still on my construction site.
Initially I only have the curve. The planes are those that carry pn pn-2 pn-1 if they are collinear then axisz= ZAXIS
Can you post it? How did you constructed the ribbon from it?
(actually the model of the screenshot above would be better to share)
What is these "pn"s you mention? Are these the curve vertices or edges (curve segments)? I cant interpret this sentence… :frowning:
What is the “axisz”? The z axis of the vehicle?
Hello Dezmo
n means the nth in French mathematics
Here is the code to create the ribbon and place the car on the ribbon for each point on the curve.
There are sometimes errors if the curve undergoes too sudden variations
model = Sketchup.active_model
ents = model.entities
car = model.definitions.filter{|d|d.name == "car"}[0]
#spline is a fredo spline in a group
spline = model.selection[0]
curve= spline.entities[0].curve
group = ents.add_group
gents = group.entities
# initialisation offset point
p0b = []
p1b = []
for i in 0..curve.edges.length do
  p0 = curve.edges[i].start.position
  p1 = curve.edges[i].end.position
  xaxis= (p0.vector_to(p1)).normalize
  origin = p1
  if i==0
    zaxis = Z_AXIS
  else
    pm1 = curve.edges[i-1].start.position
    vect = pm1.vector_to p0
    zaxis = vect*xaxis
    if zaxis.%(Z_AXIS) < 0
      zaxis.reverse!
    end
    if (zaxis.angle_between(Z_AXIS)).abs() >= Math::PI/4
      zaxis = xaxis*zaxis
    end
      zaxis.reverse!
    end
  end
  yaxis = (xaxis*zaxis).reverse
  if i==0
    p0b = p0.offset(yaxis,1.m)
  else
    p0b = p1b
  end
  p1b = p1.offset(yaxis,1.m)
  gents.add_face(p0,p1,p0b)
  gents.add_face(p0b,p1,p1b)
  gents.add_instance(car,tr)
end
Would be more easy to imagine and analyse, if I get the model (contain the spline and car), if it is not a top secret project… :wink: … Can you share the .skp file?
Hi Dezmo
No nothing “Top secret” it’s learning Ruby!
The idea is to find a generic version of path tracking by a component, to make animation. So whatever the curve, it has to be consistent. I don’t have a precise model, I change the curve each time to see the result.
I see…Learning Ruby is a good pastime :slight_smile:
:bulb: You can use the segments of the curve as xaxis and use the Vector3d #axes method to compute an arbitrary set of axes with the given vector as the z-axis direction. Then swap these vectors so that the directions are become as needed…
Hi Dezmo
Here is a variant with followme of a face along the curve.
the face must be with a little height !
face = model.selection.grep(Sketchup::Face)[0]
spline = model.selection.grep(Sketchup::Group)[0]
facepoints = face.vertices.map{|v| v.position}
curvepoints = curve.vertices.map{|v| v.position}
face_b = gents.add_face(facepoints)
curve_b = gents.add_curve(curvepoints)
road = face_b.followme(curve_b)
faces = gents.grep(Sketchup::Face)
for i in 0..curvepoints.length do
  p0 = curvepoints[i]
  p1 = curvepoints[i+1]
  origin = p1
  face_r = faces.filter{|f| f.vertices.map{|v|v.position}.include?(p0) && f.vertices.map{|v|v.position}.include?(p1)}.sort_by!{|f| f.area}.reverse[0]
  zaxis = face_r.normal
end
Purpose: An animation of a component along a curve
Here is a Downhill version of Bobsleigh!
The on-board camera at its axis of vision which follows the rolling movement of the bobsleigh in turns
:rocket:
