🔢 Basic Math and Special chars in VCB - Proposal
Hello,
After watching @JustinTSE video titled SketchUp’s Future Depends on These 10 Features, I would react on the feature request Number 3 : Math in the Value Control Box.
I agree with this need and here is a proposal :
In the latest version of the OpenCuList extension, we added a solid drawing tool and an handle tool that interact with leaf component instances. When creating these tools, we felt it was important to add support to apply some basic operations to the current mouse pointed location or to avoid repeating identical values.
The VCB can be used for many purposes. But we’ve identified 3 main uses, which are:
  • Entering distances
  • Entering quantities
  • Entering list
Using VCB is interesting because it is versatile, but it is important that it remains simple and consistent. So, entering measurements in any tools of OpenCutList follows the basic principles of SketchUp’s native tools via the VCB field. However, a few useful features have been added.
  • @ allows you to compute a simple operation using the value pointed to by the mouse
  • + - * / allows you to compute right value with @ value
  • = allows you to duplicate previous value
Note that list delimiter is ; (semicolon) instead of , (comma) if your system decimal separator is , (comma).
Examples
  • @+10 adds 10 of current model length unit to the mouse value
  • @-12mm subtracts 12 mm to the mouse value
  • -12mm is converted to 12 mm but by reversing the direction
  • @*3 multiplies the mouse value by 3
  • @/2 divides the mouse value by 2
  • 10,20 defines a pair of value v1 = 10, v2 = 20
  • 100mm= is equivalent to 100mm, 100mm
  • 50== is equivalent to 50, 50, 50
  • 10=,@-30 is equivalent to 10, 10, @-30
  • ,-10 is equivalent to @, -10
I realize that adding the @ character won’t please everyone. And that it’s much more accessible on Mac than on Windows. But adding this character allows to differentiate -12 (= distance of 12 but in the reversed pointing direction) from @-12 (= pointing distance minus 12).
Here is my small contribution.
Have a nice day and happy modeling.
When can this be useful?
To devide a distance:
To subtract from a distance:
To “reverse” a distance:
Enregistrement de l’écran 2025-10-16 à 08.48.24-GIF 720x720 15 ips
To avoid writing a value twice:
@boris.beaulant - OMG - This is EXACTLY what I was talking about!
Specifically for me, the subtract from a distance and the divide a distance are the exact use cases I wanted. I often want to push pull to a distance / 2 when I don’t have a center point to inference to.
The subtract function would be massively helpful to me when creating or editing cabinet doors, as I often want to push pull or move to a midpoint, then subtract a 1/16” of an inch or an 1/8” of an inch when adding an overlay/reveal. Right now this takes two operations - once to move the geometry, then a second move to move the geometry back 1/8”. While this doesn’t sound like that big of a deal, it adds up when you have 30 cabinet doors on a project. There are a bunch of other times I might use something like this as well.
I’ve tested out your solution and I find it fairly intuitive - adding the @ symbol before an operation flows pretty well, though I wonder if there isn’t another way to initiate the operation that’s a bit more streamlined (I’d be interested to hear from someone on the SketchUp team their thoughts on how to initiate something like this).
@TedVitale_SU - Is there someone that works with the modeling toolset over on the dev team that might want to give this a look? The way Boris has implemented this into OpenCutList is pretty smooth.
@boris.beaulant - thanks for doing this!
Yes to this request. I have used other design software that has this feature. It saves going to a calculator, then typing the number. Its something that would set SketchUp to a higher level.
The availability to copy>paste into the ‘Tape Measurement’ field would already be a step forward. (requested many times).
@boris.beaulant, I like the idea of @ in operation š and ². The third one though about avoiding to type a value twice is confusing.
I really like this idea!
I’ve also experimented with a similar input concept in my own tool, Curic DIO2, where I use the = sign followed by a length value to fix distances, and it works surprisingly well in practice.
This method saves a lot of time when editing models. For example, if you want to change a wall’s thickness from 250mm to 75mm, you normally have to do the mental math to subtract the right amount when using Push/Pull. But with the = input, you type =75, and the wall instantly becomes 75mm thick, no calculation needed.
I’m pleased to see that it can fit to your needs, Justin.
I understand. But in practice it is very useful and it saves time. Hitting , (or ; ) require to move my hand 15 cm left over the keyboard :wink:
Enregistrement de l’écran 2025-10-17 à 07.46.52-GIF 720x720 15 ips
Interesting idea too, @voquochai! It’s a bit like the native Scale tool which allows you to enter a factor or a dimension. Although in the case of the Scale tool, it’s just the use of the unit that makes the difference.
Well yes and no at the moment - the functionality is perfect for what I need, but I really need it incorporated into both the push pull tool and the move tool (unless I’m missing that feature in OpenCutList).
I’d need it to be able to adjust my geometry that I’ve created, not just work on a tool that creates all new geometry.
That being said, the way the function works is perfect!
Can we call the feature “Auto-Math-ic”?
I’m in
If we can add it, call it whatever you want! :smiling_face_with_sunglasses:
For those of us that have been around for a long time this is a no brainer as we have been asking for it for decades. At the same time we understand that as it is a simple workaround with a calc or mental arithmetic we world rather see effort put into real fixes. Many of which have been asked for repeatedly and ignored.
I saw that. This time it might be more convincing with a working example. :thinking:
Of course. I was mainly talking about a working example of use.
And maybe our Handle Tool can help you in some situations.
Do you honestly think there have been no ‘working examples’ provided in the past.
I’m especially certain that if it wasn’t added yesterday, it won’t be tomorrow. It’s a change to SketchUp’s core tools. I’m pretty sure the team won’t risk changing it.
My thread was primarily there to share an idea with other extension developers. And to try to achieve consistent use across other extensions.
Surely you would just pull out a guide line and push/pull to that?
I have to agree with this :+1:
You’re going to see a lot of this kind of thing from me - I’m just going to keep asking, and keep bringing it up. Worst case, I wasted a little time and nothing changed. Best case, someone listens
Sure, that works if you enjoy pulling out a guide every single time :grinning_face_with_smiling_eyes:
But wouldn’t it be faster to just type =75 and have it done instantly?
I do enjoy maths in my head and guide pulling, but in general, having 2-3 different ways to do an action is a strength. Would I use the VCB the way Boris describes it here ? maybe, I’m used to the standard way, and I’m good at math. so maybe not.
do I support his proposition ? you bet I do :slight_smile:
the VCB needs to understand basic maths with decimals. and from there, the extra logic proposed is totally fine.
I like math too, so let’s do a simple calculation :grinning_face_with_smiling_eyes:
Using a guide line:
  1. Switch to the Tape Measure tool
  2. Create a guide and type a value
  3. Switch back to Push/Pull to adjust the face
  4. Select and delete the guide
Using =value:
  1. Push/Pull and type the value
Anyway, totally agree that having multiple ways is a good thing for users :+1:
Even if you enjoy math, sometimes, the current size of an object is not accurate enough (e.g.: 1.33333333) to enter a final value relative to the original value that fit to the desired integer value.
In any case, it is not possible to type all the letters on the keyboard in the VCB. Because of the native limitation and keyboard shortcuts. It is therefore certain that mathematical formulas can quickly find themselves limited to numbers, operators and possibly parentheses.
