Is there a way to automatically draw arcs and circles with the appropriate number of line segments for designs that will eventually go to a CNC?
I know you can many change the number of segments when creating arcs and circles, but calculating for each one is a real pain. IS there a setting for this? An extension that automatically computes this when drawing?
where n is the number of segments per full circle, r is the arc radius, and t is your tolerance. r and t should be in the same units, but it doesn’t matter which specific unit- mm, inches, whatever. The acos function should be performed in degrees (if you want to use radians, replace the 180 in the numerator with pi).
I understand it’s not AutoCAD and it’s a free program, but for an otherwise powerful CAD program, this is a real PITA. Seems like there would be some kind of extension out there for this, but I haven’t been able to find one.
When machining metals using CNC, it is generally desirable to use enough points so that the “flats” are kept to a minimum to provide a smooth finish. On the other hand, when machining a hole (for example), it is desirable to have enough points so that the diameter is maintained to some tolerance to insure the proper size (the sagitta). For a very large circle, the number of points is substantially different than what is needed for a small circle. As @scurring pointed out, the units will cancel out in the calculation and yield only a number representing the number of segments (i.e., works in inches, millimeters, etc.). More information can be found in this thread: How many points for a smooth curve?
