I’m new here.
Lets say I get all selected edges like so:
def self.selected_edges
ss = Sketchup.active_model.selection
edgelist = []
ss.each do |entity|
edgelist.push(entity) if entity.is_a? Sketchup::Edge
end
edgelist
end
how do I make a group with them?
the following does NOT work:
group = entities.add_group
group.entities.add_edges(selected_edges)
You can only make a group directly from entities that are in the same context as the group itself.
You haven’t explained what ‘entities’ is…
Here is an example of making a group of all selected edges, if they also support faces they are cloned into the group.
It then modifies that group - here I show some text…
def self.select_edges()
@model = Sketchup.active_model
return @model.selection.grep(Sketchup::Edge)
end
def self.make_group()
edges = self.select_edges()
if edges[0]
@group = @model.active_entities.add_group(edges)
@group.name = "Selected_Edges"
else
@group = nil
end
return @group
end
def self.add_text_to_group(group)
return nil unless group
group.entities.add_text("Selected_Edges", ORIGIN, [11,11,11])
end
self.make_group() ### creates the "Selected_Edges" group in the same context as the selected edges...
self.add_text_to_group(@group) ### adds "Selected_Edges" Text into that new group.
