Alternative to get_element_value method for HtmlDialog
I was thinking along the same lines yesterday, that the method is misnamed, as it’s not a “getter” method.
It is more of a “asynchronous trigger” method. Ie …
In the linked example, perhaps it should be named request_element_value(id) ?
(EDIT: The above method rename was done in the example.)
However, what this was aimed at, was to have old code work for both UI::WebDialog and UI::HtmlDialog.
BUT, it seems this is not really possible unless the code was designed previously to work asynchronously.
So really this was a testing / proof of concept, that proved the concept incompatible with UI::HtmlDialog.
