No problem. We all were dumb once, then learned to speak. First to crawl, then to walk, later to run.
After creating the normal user account using the Admin account.
Log out and then log in to the new user account.
… This will setup all user system folders
Then start SketchUp for the first time on the new account.
… This should initialize SketchUp on that acct to “factory defaults” and create the SketchUp specific %AppData%, %LocalAppData% and %ProgramData% folders.
If you use LayOut, also start LayOut for the first time on the new user account so it also sets up and creates the user resource folders.
Then close SketchUp (and LayOut) and log out of the new user account.
Log back into the Admin account.
If you have shortcuts (keyboard accelerators) already setup, start SketchUp on the Admin account, open the Preferences dialog, go to the Shortcuts panel and export a Preferences.dat file but before saving, click the Options… button and check only shortcuts. (You do not want to save the file locations that are pointing into the Admin user %AppData% path.)
Save the dat somewhere like the Admin “Documents folder”. Then move that over to the Giselle “Documents” folder.
(You’ll import this later using the new user account.) Close SketchUp.
Now, if you do not wish to have duplicate files and subfolders, using administrative privileges, you can move:
model files (and subfolders) from say the “Admin/Documents” to “Giselle/Documents”
materials files from:
- “C:/Users/Admin/AppData/Roaming/SketchUp/SketchUp 2023/Materials” to:
- “C:/Users/Giselle/AppData/Roaming/SketchUp/SketchUp 2023/Materials”
repeat for other custom resources like:
- Classifications, Components, Plugins, Styles and Templates subfolders
If you use LayOut, do the same for the LayOut user data Scrapbooks and Templates folders, moving any custom resources from the Admin user path over to the new user account folders.
So, after all this migration, close applications and log out of the Admin account, and log in to the user account. Check SketchUp and LayOut that you can access your custom user resources.
In SketchUp, open the Preferences dialog, go to the Shortcuts panel and import the Preferences.dat file that you had copied to the user “Documents” folder. This should bring in your shortcuts.
Check that your extensions are loading and working.
