I’m using this code to create a 2D grid using components.
I create a group, define a face inside it, transform it into a component and then I copy it several times.
I would like to define a new component and add all the other components.
At the end there should be a component named “XX” that contains the other components.
How can I do that?
# Creates a 2D grid using components
n = 20 #repetitions X axis
s = 2 #repetitions Y axis
@width = 1.m #width of box
@long = 2.m #length of box
@thick = 40.mm #thickness of box
@spacing = 20.mm #spacing between boxes
@distX = @width + @spacing #pitch X axis
@distY = @long + @spacing #pitch Y axis
entities = Sketchup.active_model.entities
group = Sketchup.active_model.entities.add_group #create a group in entities
face = group.entities.add_face [0,0,0],[@width,0,0],[@width,@long,0],[0,@long,0] #define face inside group
face.pushpull (-1*@thick) #make the box
comp = group.to_component #convert group into component
comp.name = @long.to_s + " x " + @width.to_s
(0..n-1).each { |i| #copy X axis
(0..s-1).each { |j| #copy Y axis
if !((i==0) && (j==0)) #don't copy yourself
transformation = Geom::Transformation.new([i*@distX,j*@distY,0])
componentinstance = entities.add_instance(comp.definition, transformation)
end
