Hi.,
As my knowledge, it is possible to add entity inside a group. is there is anyway to access a particular face of the group ( ex: a cube of size 1m,1m,1m, consist of 6 faces) and apply different material to each face.
Thanks
Hi.,
Thanks
It is quite possible, though the technique you will need to use depends on how much you know about the Face(s) you want to paint. Some examples:
face = my_group.entities.add_face(points)
face.material = some_material
array_of_faces = my_group.entities.grep(Sketchup::Face)
Hi slbaumgartner,
Thanks for the info. I am creating a face with four points in an array, with each point has a set of x,y,z values defined. Then using push pull to make it as panel. Then grouping it all connected faces as a single group. Now would like to access each face for applying the materials like laminate on the vertical surface (I.e two sides, which has bigger area)and rest of faces with edgeband.
The code follows something similar
Default code, use or delete...
mod = Sketchup.active_model # Open model
ent = mod.entities # All entities in model
sel = mod.selection # Current selection
#declaration of variables
height = 720.mm #Height of the cabinet
depth = 550.mm #depth of the cabinet
wd = 600.mm #width of the cabinet
thickness =18.mm #thickness of the panel
# Left side Panel
pt = [0,1,2,3]
pt[0] = [0,0,0]
pt[1] = [thickness,0,0]
pt[2] = [thickness,depth,0]
pt[3] = [0,depth,0]
#creation of face - LH Side panel
face = ent.add_face(pt)
face.reverse!
face.pushpull(height, true)
lh_group = ent.add_group face.all_connected
lh_group.name= "LH Panel"
This workflow is backwards. If you draw in the model entities context, your new geometry will interact and intersect with other geometry that you (or the user) has drawn in that context.
Instead, create an empty group, and add your geometry to the group’s definition’s entities.
(The group class has a shortcut method to get at their definition’s entities collection.)
# Assume laminate_matl and edgeband_matl already point at the
# desired material objects in the model's materials collection.
# Creation of Side panel
def create_side_panel(pts, height, laminate_matl, edgeband_matl, name= "Panel")
group = Sketchup.active_model.active_entities.add_group
face = group.entities.add_face(pts)
fail "Error creating face from points." if !face
face.reverse!
group.name= name
grp_faces = group.entities.grep(Sketchup::Face)
fail "Error pushpulling face." if grp_faces.size <= 1
big_faces = grp_faces.max(2) {|a,b| a.area <=> b.area }
lil_faces = grp_faces - big_faces
big_faces.each {|face| face.material= laminate_matl }
lil_faces.each {|face| face.material= edgeband_matl }
return group
end # Check that group is valid in calling code!
Once the group is successfully created, use group.transform!
to move, rotate or scale the group instance to the position desired.
Thanks Dan, will check it out
As @DanRathbun says - group = entities.add_group()
[i.e. it’s empty] and then immediately add your geometry into that group.entities
Also add this group to the model.active_entities
context rather than the model.entities
context.
This allows the code to work logically, even if the user is inside an edit…
Thanx, fixed the example.
