When Pella dynamic components are imported (or loaded directly) into SU, they are not interactive as advertised. I have tried several, the behavior is the same. When the interact tool is used a dialog box appears, “Please open component options”, but no interactivity. (see GIF below)
Attached is the Pella file.
Pella Architect Series Contemporary Hinged Door In-Swing Double FA-AF.skp (1.8 MB)
When I do the same with Marvin components they behave as expected.
In the 3DW the Pella component has the “dynamic” symbol.
I must be missing something simple, but I am “clueless”.
Any help appreciated.
Well, ok, thought it was something simple, and it was.
Just because a Pella Door/Window is dynamic, does not mean it will open/close using the interact tool. Dynamic in this case means one can adjust the sizing of the door.
Different vendors add additional behaviors into their dynamic components, such as Marvin.
I was simply reading into a vendor’s offering what I expected, my bad ![:slightly_frowning_face: :slightly_frowning_face:](https://emoji.discourse-cdn.com/twitter/slightly_frowning_face.png?v=12)
Right. And in my opinion the Pella dynamic components are the more useful … because they deliver properly modeled windows for the sizes they offer. Makes it quick and easy to put “real” windows into a model for a client.
This is significantly more useful than being able to show a client that windows in the model of his/her house open/close. Although … I must admit … occasionally I have delivered models with operable doors. In tight areas operable doors can help a client “see” how a small space functions … bathrooms, pantries, laundry rooms, hallways etc.
Flex Tools doors open and close on with the interact tool, but they are generic, not specific to any manufacturer.
You are absolutely correct! Accurate models in size, shape and appearance are critical in the designer/client interactions.
And to give Pella credit, their dynamic doors/windows have the ability in component options, to show the assembly in the open/close static position.
Although, Marvin’s dynamic behavior allows for moving in and out of the model (through the door/window) somewhat easier, as you point out.
