All of the rigging for sailboats must be 3D, not just a line to be printable, is that right? If so, how can I draw a 3D line representing the rigging for the sailboat?
Albert Drybrae
Albert Drybrae
If you want the rigging to print then yes it will need volume. Standing rigging lines would need to be a cylinder for example. I often draw rigging using the extension pipe along path. The challenge I see here is that to make a decent 3D print that will work the rigging lines will need to be disproportionately thick and look odd. I think if I was doing this I would print the hull and mast then add the rigging after using string. I suppose you could use raw filament and spot melt it in place for the rigging to give the print a monolithic look in color and material if that’s what you are going for.
Or maybe use 20lb test fishline for the rigging
