Hi, I’m designing a Thematic Park and need to STAMP A MAP OVER A DOWNLOADED GOOGLE EARTH LOCATION.
Let me explain myself a little bit.
The Park contour is South America, therefore,over an area of 300 acres I need “stamp a South America map”.
At least that somebody give me a better idea.
DaveR
May 31, 2016, 1:48am
2
Import the map as a texture. Then apply it to the terrain model you’ve added from Google Maps and unlocked.
… and you can use the ScaleTool to size it to fit into the 300 acre lot.
Geo
May 31, 2016, 12:20pm
4
gcuenca7:
Hi, I’m designing a Thematic Park and need to STAMP A MAP OVER A DOWNLOADED GOOGLE EARTH LOCATION.Let me explain myself a little bit.
The Park contour is South America, therefore,over an area of 300 acres I need “stamp a South America map”.At least that somebody give me a better idea.
What you’re trying to accomplish is to Project an image of a map onto the Surface of the imported terrain.
See the method described in this topic:
Here’s a method that may work for you.
Above your terrain, create a single plane of geometry, the same size or a bit larger than the terrain.
Paint the plane with the texture.
Edit the texture transparency so you can see through it to the terrain below.
[image]
Set the camera in Top View and Parallel Projection.
Position the texture in relation to the terrain as needed.
Position Texture Tool — SketchUp Help
When the texture is in the proper position, right context click on the face > …
