Okay I changed it back.
The changed test code ...
class TestTool
RED ||= Sketchup::Color.new("Red")
def activate
@ip = Sketchup::InputPoint.new
@ip1 = Sketchup::InputPoint.new
@mode = 0
@edge = nil
@vertex = nil
Sketchup.status_text= "Pick a edge."
def deactivate(view)
view.invalidate
def draw(view)
view.tooltip= @ip.tooltip
@ip.draw(view)
if @mode > 0
view.drawing_color= RED
view.draw2d(GL_LINES, @edge.vertices.map(&:position) )
view.draw_points(@ip1.position, 10, 1, RED) if @ip1.valid?
def onCancel(reason, view)
# Restore the vertex and reset the tool:
view.model.abort_operation if @mode == 2
deactivate(view)
activate()
def onLButtonDown(flags, x, y, view)
if @mode == 0
ph = view.pick_helper
ph.do_pick(x, y)
@edge = ph.picked_edge
if @edge
@mode = 1
onMouseMove(flags, x, y, view)
elsif @mode == 1
@ip1.pick(view, x, y) # Here is the only place to change @ip1
vertices = @edge.vertices.sort do |a, b|
a.position.distance(@ip1.position) <=> b.position.distance(@ip1.position)
@vertex = vertices.first
# @vertex = @edge.vertices.find { |vertex|
# vertex.position == @ip1.position
if @vertex
@mode = 2
view.model.start_operation('Move Vertex')
elsif @mode == 2
# Stop moving the vertex and reset the tool:
view.model.commit_operation
deactivate(view)
activate()
def onMouseMove(flags, x, y, view)
@ip.pick(view, x, y)
if @vertex
pt = @vertex.position
vector = pt.vector_to(@ip.position)
tr = Geom::Transformation.translation(vector)
view.model.active_entities.transform_entities(tr, @vertex)
if @mode == 0
Sketchup.status_text= "#{@ip.position.inspect}: Pick a edge."
elsif @mode == 1
if @ip1.valid?
puts "@ip1: #{@ip1.position}"
else
Sketchup.status_text= "#{@ip.position.inspect}: Pick a point."
elsif @mode == 2
Sketchup.status_text= "#{@ip.position.inspect}: Drag the vertex."
view.invalidate
def onSetCursor()
UI.set_cursor(633) # 633 is Select cursor
Sketchup.active_model.select_tool TestTool.new
I do not see this happening. The closest vertex to @ip1 is chosen correctly.
What I do notice is the after picking @ip1 the mouse needs to move a bit before the tool shows the next @mode. Which shows the vertex being dragged.
So to fix this, I added a internal call to onMouseMove(flags, x, y, view) from within the onLButtonDown(flags, x, y, view) method when @vertex is good.
