Hooray to BruceYoung!
Here is the slightly more flexible demonstration of what he has just said.
# Given the definition of a (Sketchup) circle and an arbitrary chord of that circle
# - add a linear dimension that is on the plane of the circle
# - parallel to the chord
# - and offset to the outside of the circle
model = Sketchup.active_model
ents = model.active_entities
model.start_operation('Dimension Chord', true)
# define a circle
radius = 10
num_segs = 48
centerpoint = [0, 0, 0]
circle_normal = Geom::Vector3d.new 0,1,0
edges = ents.add_circle(centerpoint, circle_normal, radius, numsegs = num_segs)
# choose a chord at random from the vertices of the circle
i1 = rand(num_segs)
i2 = rand(num_segs - 1 ) + 1
i3 = (i1 + i2) % num_segs
a = edges[i1].start.position
b = edges[i3].start.position
# draw the chord between the two points
ents.add_edges([a, b])
# Add a dimension that is offset from the chord and on the plane of the circle
# The cross product of a normal(a vector) and an edge(a vector) yields a third vector
# which is perpendicular to the plane defined by the first two vectors
offset_vector = circle_normal.cross(a.vector_to(b))
# scale the offset vector relative to length of the radius
offset_vector.length = radius / 5.0
# reverse the offset vector if it is pointing to the interior of the circle
radius_to_a = centerpoint.vector_to(a)
length = (radius_to_a + offset_vector).length
if length < radius
offset_vector = Geom::Vector3d.new(0,0,0) - offset_vector
# add the dimension
ents.add_dimension_linear( a, b, offset_vector)
model.commit_operation
