A nice long Saturday session. My wife, realizing that I have a real deadline on this project, has relaxed the, no-model-building-on-weekends rule. And I took advantage of it.
This was a particularly important session that had consumed a lot of my creative juices. I couldn’t measure the gun house bulkheads until all the stuff below it was done. I needed the pan deck to be stabilized and by gluing it to the e-deck accomplished that. Each bulkhead had to be hand-fitted because of end compartment variations.
Before doing any of this, I did some airbrush touchup of the now-fully-cured epoxy joint, which is now looking great.
The two outside bulkheads, with the large opening, were actually the easiest to do since they didn’t interact with the powder hoist trunks. The hoist trunks also couldn’t be finalized until I created the bulkheads… sort of a chicken/egg scenario. As it worked out, the hoist trunks needed some elective surgery. I was never really sure of the interaction of the bulkheads and the trunks and was going to play it by ear once I got to that point.
To cut the square corners in styrene (or wood) I use the right-angle chisel I got from MicroMark years ago. For scratch-building sytrene it’s really great.
I use it in the drill press. I stack up wood packing under the table since the pressure is so high when punching the table lock can slip. The packing provides a solid, immovable base so the chisel works as designed. I pre-scribe the cut lines giving the chisel a positive engaugement position. It’s easier for me to leave the chisel in this positiion and rotate the work around to pick up the other corners than to spin the chuck around by hand.
A particularly challenging bulkhead was the one that’s going to have the open powder door. This image shows the opening before I made it a little wider so the door frame fully occluded the opening’s edges. BTW: that cradle also broke while doing all this manhandling. I had another good one printed, so I painted it and fixed this one. Once the compartments are glued into the gun girder, those delicate spanning trays will be out of harm’s way and won’t constantly get broken. The critical fit was the butt joint between the styrene bulkhead and 3D resin printed compartment. I made the compartement walls 0.040" to match the styrene’s width when assembled.
Here are all six bulkheads taped in place for a beauty shot. Obviously they’re all out of alignment, but won’t be when installed permanently.
I have some left over Archer Fine Decal rivet decals that I used when building the girder bridges on my model railroad 8 years ago. There are rivets on panels in these buikheads and I decided to add them only on the viewer-facing ones. First I scribed the panels at a scale 3’ width. I then added decals that looked apropiate. In one of my images I notice that there is a break in the bulkhead right in the area of of the trunnion caps to permit access to them for maintenance. Not sure if I’m going to add this since I have no really good information on what it actually looks like. It under the gun house roof area so won’t be to obvious if I don’t add them.
This is all the bulkheads… Note the little relief cuts in area over the trunnions. That’s to clear the trunnion bolts. They weren’t sitting down correctly without them.
And here are the three that will have rivets. Notice that I cut two strategic cutaways that will expose the gun slide’s flanks and the hoist machinery. With this riveting, I will have to paint the panels.
While “adjusting” the double hoist trunk, the thin separation panels that stick up, broke apart (the second time, I might add). I removed all of it down to good material and rebuilt this part with styrene. The reason for the adjustment was the width. I neglected to add relief for the bulkheads. I probably thought at one time that the flank of the trunk would serve as the bulkhead, but decided against it. You can see the surgical scar on the trunk’s flank. It’s completey covered by the bulkhead.
Getting these bulkheads cut and fit is huge! It, like joining the shells and the e-p deck joint, were very hard to predict the outcome. I did many iterations in my head about how this could go, but until I started cutting and fitting, I was never sure it would work out. It has and the rest of the work is going to go pretty well. I only have a very few parts that need to be installed. I’m predicting that the turret itself will be done by next weekend, leaving a few days to build the remaining kit parts, the crew members, the display case and finally any accompanying graphics. It should all be ready on time. If I had any doubts that this would come out as I envisioned and drew it, those doubts are now dispelled.
