Ruby block changes not reflected when reloading extension
You are not showing a generic Ruby block but actually a block argument to the UI::Command constructor. This block is converted to a Proc object and stored for use by the MS Windows menu command object.
These OS objects cannot be redefined or more specifically if they could, the SketchUp API does not exposed this. One of the main reasons we can surmise is security, so that “bad actors” cannot redirect existing commands to do nefarious purposes.
Fortunately, the workaround is simple. Do not put the command code in the block argument.
Instead, all command blocks should have one statement calling a local method that has the command code.
Methods can be redefined at any time, so you can tweak the code, reload, test, tweak again, repeat, … as many times as you need.
One of the paradigms I use often us to group my command methods together using a "command_" or "cmd_" prefix. (Ie, I always have my methods listed in alphabetical order within types. Ie, I group command methods and observer callback method, etc. together in groups and in alpha order within these groupings.)
So, for example …
module SomeAuthor
  module SomePlugin
    extend self
    #{# COMMANDS
      def cmd_nifty
        # This code can be redefined at any time ...
    #{# RUN ONCE BLOCK
    if !defined?(@ui_loaded)
      cmd = UI::Command.new("Do Nifty Thing") { cmd_nifty() }
      @ui_loaded = true
What are #{# blocks? (...click to expand...)
The #{##}# blocks are collapsible blocks in Ruby (at least in Notepad++). They can be used to collapse and expand large portions of the code to enable better navigation.
