The image looks perfect (with the color ofc :D)
I get this error however,
SLB:Massing.massing
Error: #<NoMethodError: undefined method `massing’ for :Massing:Symbol>
OH SO CLOSE
SLB:Massing.massing
OH SO CLOSE
Ack, silly typo! The last line should say
SLB::Massing.massing
I omitted one of the colons! Fixing it in the previous post.
Off to a concert now. I hope the last version works ok. Otherwise I will be off line for some while.
You are amazing! Check your pm <3 <3
Just as an exercise I wrote up a filter method that finds all the bottoms of buildings …
def select_groundplane_faces_with_vertical_walls()
Sketchup.active_model.entities.grep(Sketchup::Face).select do |f|
f.normal.parallel?(Z_AXIS) && # horizontal AND
f.vertices.all? { |v| # whose vertices are ALL
v.position.z == ORIGIN.z && # on the ground plane AND
v.faces.size > 2 && # have at least 3 connected faces AND
v.faces.reject { |f| # ( those faces NOT
f.normal.parallel?(Z_AXIS) # horizontal
}.all? {|wall| # are ALL
wall.normal.perpendicular?(Z_AXIS) # perpendicular to the Z axis.)
end
end
… this would allow the roofs to be any shape. BUT, the buildings must have a bottom face.
