Thank-you,
I am separating the code by following your example from the GitHub link.
begin
path = "C:/MySketchupDialog/"
# Create a hash of replacement strings from dialog resource files:
replacements = {
:stylesheet => File.read(File.join(path, "stylesheet.css")) ,
:javascript => File.read(File.join(path, "javascript.js" )) ,
:json_data => File.read(File.join(path, "some_data.json"));
:draw_box => File.read(File.join(path, "drawBox.rb"))
html_text = File.read(File.join(path, "dialog.html"))
rescue => err
# Handle IO errors
else
@dialog = UI::HtmlDialog.new(
:dialog_title => "Dialog Example",
:scrollable => true,
:resizable => true,
:width => 500,
:height => 300,
:left => 200,
:top => 200,
:min_width => 150,
:min_height => 150,
:max_width =>100,
:max_height => 50,
:style => UI::HtmlDialog::STYLE_DIALOG
# Insert the replacement file text into the HTML and pass to dialog:
@dialog.set_html( html_text % replacements )
@dialog.show
I have a separate file for the drawBox.rb but unsure where to call it.
drawBox.rb file
require "sketchup.rb"
dialog.add_action_callback("getUserInput"){|action_context,nm, user_input1, user_input2, user_input3|
Sketchup.active_model.entities.clear!
width = user_input1.to_f
length = user_input2.to_f
depth = user_input3.to_f
model = Sketchup.active_model
entities = model.active_entities
UI.messagebox(nm)
pts = []
pts[0] = [0, 0, 0]
pts[1] = [width, 0, 0]
pts[2] = [width, length, 0]
pts[3] = [0, length, 0]
# Add the face to the entities in the model
face = entities.add_face(pts)
face.reverse! unless face.normal.samedirection?(Z_AXIS)
face.pushpull depth
require 'fileutils'
FileUtils.mkdir_p("C:/MySketchupDialog/#{nm}")
box_Info = [
{ Name: nm , Width: width, Length: length , Depth: depth }
require 'csv'
CSV.open("C:/MySketchupDialog/#{nm}/testMyCsv.csv", "w") do |csv|
csv << ["Name", "Width", "Length", "depth"]
box_Info.each do |bx|
csv << [bx[:Name], bx[:Width], bx[:Length], bx[:Depth]]
javescript has this:
function sendDataToSketchUp() {
var nm = document.getElementById('nam');
var user_input1 = document.getElementById('id1');
var user_input2 = document.getElementById('id2');
var user_input3 = document.getElementById('id3');
alert("name: " + nm.value + " width " + user_input1.value + " Length: " + user_input2.value + " height: " + user_input3.value);
sketchup.getUserInput(nm.value, user_input1.value, user_input2.value, user_input3.value)
The alert does come up with the correct results.
The console does error when I click the button, saying “getUserInput” is not a function, I assume it’s because I haven’t called drawBox.rb yet.
