Try to take notice of what the filename is in the Export dialog.
I do not know why but sometimes the underscores get changed to dashes.
This causes the extension to be testing for the incorrect filename.
I am still on Win 10.
Okay, after thinking a bit, and remembering that I has also gotten the dialog twice for the first “Front” view, …
I make a few tweaks to hopefully make sure that the dialog was only being opened once per camera view.
Version 1.1.1
- 2024-02-18 (Dan Rathbun)
Increase the dialog DELAY
constant to 1.5 seconds.
export_dxf_view()
: Use true
for 2nd UI.start_timer
argument and then
cancel the timer on the first call into the block.
onViewChanged()
: Detach the observer before calling the method to
open the export dialog. We are trying to avoid double calls into
the export_dxf_view()
method for the same camera view export.
Example_BatchExportDXF_1.1.1.rbz (4.6 KB)
I have only tested with a local model file and writing to local physical disk drives.
Network storage has been known to have latency that causes issues with SketchUp.
Morning Dan, thanks for the update!
Aha! I think that must have been the issue as we work off a shared NAS drive. Running the plugin locally seemed to do the trick! Thanks so much for all your help with this. Really appreciate it
Ruby has the FileUtils
module that can be used to copy files.
