Could you please help me with my files. I had error 17 code when suddenly cannot autosave it , i save a copy myself but both not working afterward.
I could open the file ok. I saved a new copy, see if this works for you:
FWIW, I look at the SketchUp model for this viewport in your LO document.
I corrected a little bit of incorrect tag usage and purged unused stuff from the file.
Then I looked at the remaining textures.I found one that is extremely huge. Must larger than it needs to be. I resized it to make a respectable texture.
After that cleanup the file size was reduced by 98.2%. I don’t have time to go through the other five SketchUp references but I wouldn’t be surprised if they would show similar file size reductions. It would make your work easier if you’d clean up your SketchUp models before you add theem to LayOut.
