Every few SketchUp releases they break the console somehow, or the IO return from system commands.
Somewhere I posted a fix for the system (global backtick) methods.
Ah here it is … Getting unique ID of a user's machine - #5 by DanRathbun, post 5
Here’s an example using Fiddle
that comes out of the box with Ruby:
Biggest challenge was navigating the Win32 API and all their layers of compatibility overloads.
The link is down.
Oops, I’d created it as a private repo. I just made it public, please try again.
there is no need for the CLIPDIR
on mac…
def copy(text)
`echo "#{text}" | pbcopy`
end
def paste()
`pbpaste`
end
# in >>
copy('copy can be less complex')
# << out
paste.inspect
# returns =>
"copy can be less complex\n"
# so you need to be aware of the \n...
# or use chomp and add your own formatting if needed...
def paste()
`pbpaste`.chomp
end
john
I put the CLIPDIR and “clip.txt” on both platforms for 3rd party applications, just in case those needed to read from a file. The OP never said what the other applications were, what their scripting capabilities were, etc.
# so you need to be aware of the \n... or use chomp
Added .chomp
to above example. (I had it on Windows already.)
Not sure why this was flagged - it’s as good an answer as any in this thread. A cut/paste workflow seems like the worst of all worlds solution - bottom of the barrel stuff. Surely a better solution exists, or at the least an automated one. Automation is exactly what computers are good for.
Perhaps if we had more information on the external software.
Yes, I was surprised at the reaction to my contribution. But not offended.
I agree with you that knowing more about the problem posed its a necessary to giving a better answer.
Seasons greetings!
