Cannot install ruby gem in OSX
No success so far.
Downloaded the rep from here (version 5.03)
Replaced line 352 (not 353) with
VALUE top   = rb_define_module("RG");
and line 354 with
VALUE mod   = rb_define_module_under(top,"Clipper");
Also updated version.rb with
module RG::Clipper
  # Keep first two components sync'd to Clipper's major/minor.
  # Last is our build number based on that.  Hopefully there
  # won't be too much churn re: Clipper's version vs. the bindings.
  VERSION = "5.0.3"
end
Then I run
rake install
but i get the error
rake aborted!
There was a NameError while loading clipper.gemspec:
uninitialized constant RG from
  /Users/ruggiero/Downloads/rbclipper-master/clipper.gemspec:4:in `<main>'
I have also tried without any modifications to the files.
Once i have replaced ‘vector_salad’ with ‘clipper’ (no idea what vector_salad means) in the clipper.gemspec file and commented
s.licence     = "Boost Software License - Version 1.0"
because of no method error, it seems to work fine.
I have tried to move the ‘.o’ (there are no .so created) files from the gem folder created in my plugin folder, but no success. The require ‘RG/clipper’ does not give any error, but then Clipper is not recognized.
Honestly, I have spent a few hours testing various things, but i am really lost at this point.
Any tip?
To get the “production” gemspec, it’s best to download from the Rubygems gem server:
https://rubygems.org/downloads/ruby_clipper-5.0.3.gem
The gem installer will download the gem from Rubygems server for you.
FYI: gem files are gz archives and can be opened with 7Zip.
Anyway I ran the “setrbvars.bat” in my System Ruby install, then ran irb.bat, and from within the IRB shell I called:
Gem::install "ruby_clipper"
It was built (after having to tell Comodo to allow several programs to run.)
After the rake task it wrote the gemspec file to :
C:\Ruby200\lib\ruby\gems\2.0.0\specifications
This is what it looks like. (So the one you have, has some quirky things in it, meant only for his [the authors] development repo setup.)
# -*- encoding: utf-8 -*-
Gem::Specification.new do |s|
  s.name = "ruby_clipper"
  s.version = "5.0.3"
  # more gem attributes ...
  # see full file attached (below)
end
ruby_clipper-5.0.3.gemspec.rb (1.3 KB)
@DanRathbun,
on the mac system gem install for irb the spec varies on the gem version
s.rubygems_version = “2.0.14”
further investigating shows…
irb(main):015:0> Gem.rubygems_version
=> Gem::Version “2.0.14”
# Ruby Console
2.0.3
could the fact they differ break gems on a mac?
john
I don’t know as do not have a Mac. And I purposely installed the same-same as SketchUp has for testing, etc.
Two modes of updating rubygems:
$ gem update --system
… or if that doesn’t work:
$ gem install rubygems-update
$ update_rubygems
But you may get a newer version than what SketchUp has.
That came from:
http://docs.seattlerb.org/rubygems/UPGRADING_rdoc.html
After some good reading of rubygems excellent documentation I got it work on the system Ruby. These are the steps assuming that the gem is downloaded in the Download folder
First download the gem from https://rubygems.org/downloads/ruby_clipper-5.0.3.gem
Unpack the gem
gem unpack ruby_clipper-5.0.3
cd ruby_clipper-5.03
Modify lib/clipper/version.rb adding the top level namespace
module Clipper
to
module RG::Clipper #RG is my top level namespace
Now modify the rbclipper.cpp from
VALUE mod   = rb_define_module("Clipper");
VALUE k = rb_define_class_under(mod, "Clipper", rb_cObject);
  rb_define_singleton_method(k, "new",
                         (ruby_method) rbclipper_new, 0);
to
 VALUE top   = rb_define_module("RG"); #Top level namespace
 VALUE mod = rb_define_module_under(top, "Clipper"); #Clipper module under RG namespace
Now clipper is under the top level namespace RG.
We need to create the gemspec file. Move back to Download and extract the gemspec file from the original gem (this has not changed). This command extracts the gemspec file in ruby format (–ruby)
gem spec ruby_clipper-5.0.3.gem --ruby > ruby_clipper-5.0.3/ruby_clipper-5.0.3.gemspec
Now we need to rebuild the gem. Move back to the gem folder
cd ruby_clipper-5.0.3
and build the gem using the gemspec file just created
gem build ruby_clipper-5.0.3.gemspec
At this point we can install the modified gem from the local file (we are still in the gem folder)
sudo gem install --force --local ruby_clipper-5.0.3.gem
--force #Ignore dependencies
--local #Restrict operations to the LOCAL domain
The (modified) gem is now installed in system Ruby.
In irb we can write
require 'clipper'
c = RG::Clipper::Clipper.new
and get
=> #<RG::Clipper::Clipper:0x007f8ea232ca48 @multiplier=1048576>
Now I move
/Library/Ruby/Gems/2.0.0/gems/ruby_clipper-5.0.3/ext/clipper/clipper.bundle
to my SU RG folder
Users/ruggiero/Library/Application Support/SketchUp 2015/SketchUp/Plugins/RG/ext
but when i require clipper
require 'RG/ext/clipper'
I get a ugly bug splat!!!
Am i doing something wrong?
Thanks
Yup.
In normal “system” Ruby (and actually also in SketchUp Ruby,) when you require a gem that is already installed, the rubygems system pushes the gem’s path with it’s “lib” subdirectory appended, into the $LOAD_PATH array, temporarily.
Then it calls require gemname.
So this means there is usually a script or object file by that name in the “lib” subdirectory, (ie, “clipper.rb”, or “clipper.so”, or “clipper.o” etc.)
It is also common for the gems support subdir to also have that same name.
So it’s the clipper gem’s “lib” subdirectory that is the “ready for primetime” directory.
So to mimic what rubygems does, you put that “lib” subdirectory inside your own plugin subdir, and temporarily push it’s absolute path onto the $LOAD_PATH array (aka $:.)
From your plugin loader.rb:
lib = File.dirname(__FILE__)<<"/lib"
$:.unshift( lib )
require "clipper"
require "clipper/version"
$:.delete( lib )
Add: You could likely in your case, skip the path pushing because there are only two files, but in the case of “rubyzip” there are a whole bunch of files in the “zip” subdir that get loaded via require calls, so the “/lib” path needs to be in the $LOAD_PATH array temporarily.
SO this would also work:
require "RD_ThisPlugin/lib/clipper"
require "RD_ThisPlugin/lib/clipper/version"
Thanks Dan.
I have tried both options.
I copy the lib folder in my RG plugin folder, but when I call
require "RG/lib/clipper"
I still have bugsplat
This is the content of my RG folder
RG
├── RG_tests_core.rb
├── clip.rb
└── lib
    ├── clipper
    │   └── version.rb
    └── clipper.bundle
Is it possible that there is a version issue?
Sketchup
puts "#{RUBY_VERSION}-p#{RUBY_PATCHLEVEL}"
2.0.0-p247
Mac
ruby 2.0.0p481 (2014-05-08 revision 45883) [universal.x86_64-darwin13]
More generally. If a C extension is self contained, is it always supposed to work in Ruby?
I can’t say much about compiling on Mac, as I don’t have one.
I believe Mac developers install RVM, and then install Ruby 2.0.0-p247, and compile with the same version SketchUp has.
Sorry this is such a pain dealing with gems. The SketchUp rubygems implementation needs work.
It would nice if plugins could just require them. (Ie, a gemserver at sketchup.com.)
It seems that I have to give up then. Thank you very much for your help Dan.
Well if I have to guess I’d say compiler switches.
Can you get the PC edition loading ?
Your other option is to repackage as 3 pre-compiled gem archives, and copy the appropriate one to the users’s SketchUp gem cache directory, then use Gem::install, but you’d need to make the gem a unique name. Likely prepending your “RD_” namespace identifier to the gem file name.
Yes, the PC version works fine. Quite straightforward in that case. I just copy the .so file.
Well you need two, one for 32bit and one for 64bit.
