Passing data from WebDialog to Ruby
How to send more then only one parameter from WebDialog to Ruby?
function callRuby(htmlpage) {
// Declare the variable with “var” so that it is not global.
var query = ‘skp:pass_data@’ + htmlpage;
window.location.href = query;
How to write line: var query = 'skp:pass_data@’ + htmlpage;
Please use the ```javascript or ```ruby blocks to surround code in forum posts.
In the <head> element, within the <script> element:
// Call Ruby with a parameter string of comma separated values:
function callRuby(params) {
    // Declare the variable with "var" so that it is not global.
    var query = 'skp:pass_data@' + params;
Somewhere in the HTML body or another JS function send some data:
callRuby('Mamjanowski,48,5.678,etc.,I love SketchUp');
In Ruby:
@dlg.add_action_callback("pass_data") {|dlg,csv|
  param_array = csv.split(',') rescue []
  # use your param_array of passed data
  puts param_array
>> outputs:
["Mamjanowski", "48", "5.678", "etc.", "I love SketchUp"]
Basically, you can use whatever delimiter you choose, not just a comma. Use a semi-colon ';' if you prefer.
Some coders send JSON strings, but that needs to also send all the fieldnames, which is not always needed.
