The first time I right click a group of objects and select “Make component” it takes ages. After that Make Component is instantaneous every other time I use it.
This is the case after I first open a SketchUp model, or start working on a model that has been minimized for a long time. I get the blue spinning circle for between 1 and 2 minutes and must wait.
It happens on all reasonably big models.
I’ve tried disabling all plugins via ruby console and this does not help.
It happens to me too. I have around 150 200 unique components.I am not sure if it is because of the great number or something else.
In a new document it saves almost instantly but in a model with about 160 components it saves in about 4-5 seconds- but just the first save, after that it saves almost instantly.
I have a powerful PC with 24GB ram.
I usually have a few things running, but I checked and its the same even if I close down everything except SketchUp.
I’m stuck on SketchUp 2013 as I use a space navigator and it I can’t use it with newer SketchUp’s due to reason here
That is unfortunate. SU2013 is 32-bit which has a (~3GB) limit for each process. When you can get up and running on SU2015 or higher, 64-bit, your limit should be upward of 8GB.
Not to mention SU2014+ runs Ruby 2.0 which is much faster than Ruby 1.8. Add in 3 years of improvements, etc.
I’ll just use a generic 3-button mouse, and stay away from the 3dconnexion porducts.
